Open wheeler gets a birthday
And I thought stripping a cylinder head for re painting was fun!
Elfin Monocoque (Twin Cam)
[email protected]
[email protected]
SJ Lambert - Fourth Gear
[email protected]
[email protected]
[email protected]
[email protected]
Aiming to get back to this
[email protected]
[email protected]
[attachment=0]image.jpg[/attachment
Some ancillary bits got a clean up today.
[email protected]
[email protected]
[email protected]
[email protected]
[email protected]
[email protected]
Main frame getting some attention.
[email protected]
[email protected]
The steel fuel pipe that can be seen on the rear right hand side (right hand foreground) & is mounted by welding at it's for & aft attachment points has cracked at it's front weld (seemingly more than once).
As it's encased within the monocoque structure we're looking to hit upon a fix that will be ultra reliable.
Our theory as to it's failure is engine vibration being directly transmitted to it (I suppose it's possible that it was just a poor weld initially & that subsequent repairs didn't improve things greatly).
Anyway, thoughts so far are:
- re weld a one piece pipe back in and place a damping sleeve over it
- replace with a two piece pipe with a flexible joiner
- (on the "what if" spectrum) re weld a one piece pipe in with some droppers from the top rail of the skeleton attached to it.
- I'm open to anyone's thoughts on any of the above as well as additional ideas!!!!
Cheers James
Cheers James
[email protected]
[email protected]
I think I would use a bulkhead compression fitting for connecting thin wall tubing through a thin wall bulkhead.
The fitting has a compression fitting each end and the middle is threaded for clamping to the bulkhead using nuts and washers on each side.
Swagelock are the type of fittings I am familiar with but there are others similar.
http://www.coleparmer.com/buy/category/ ... on-fitting
I think trying welding in this situation will always crack with vibration
Welding in a repair section into top rail today.
Blasted the skeleton this afternoon. Primer tomorrow.
[email protected]
[email protected]
[email protected]
[email protected]
That's a project and a half and coming along nicely. Do those all end up being bucked aluminum aircraft rivets or Cherry rivets?
You have to love clecos!
Bud
1970 +2S Fed 0053N
1970 +2S Fed 0053N
- Bud English
We've got Cherry rivets on hand, but are mostly using some blind Rivets from another manufacturer as they resemble the originals closely.
We're loving our 200 skin pins something fierce. Took delivery of 70 screw up ones today to compliment the Clecos.
Headed back tonight to chromate prime the skeleton. Plan to rivet tub back together Saturday morning.
[email protected]
[email protected]
[email protected]
[email protected]
