Chop sticks Ali or Stainlless?
• Page 2 of 4 • 1, 2, 3, 4
A number of suppositions about how Archimedes did it.
http://www.math.nyu.edu/~%20crorres/Arc ... Intro.html
Rather than try measuring overflow, this might be simpler.
Use a lightweight spring balance.
Weigh as many chopsticks as you have got, first with them in air , them with them immersed in water but with the spring balance out of the water.
The difference between the two readings is the weight of water displaced so divide that into the weight of the chopsticks in air to get the desity (?)
take a 2p coin and lightly scrape the edge against the metal, aluminium will scratch very easily, stainless will not. your sticks are almost certainly made from Grade 316 stainless steel, otherwise known as Marine Grade or Medical Grade. This grade of stainless is not magnetic as you have already noted.
Polished aluminium unless anodised will go a dull colour very quickly, think of your old pots and pans ( Mum's or Gran's). Being a relatively soft metal, aluminium is not often used for any sort of eating utensil.
Kindest regards
Alan Thomas
Alan Thomas
That will do me mate...
The alloy used to make 2p pieces is not as hard as grade 316 but certainly tougher than all aluminum alloys including 95% of all anodised finishes. If the manufacturer of these rather mundane items has gone to the vast expense of applying an industrial coating normally reserved for bearing surfaces then the 2p alloy will act as a touchstone by depositing metal im the surface of the object, grade 316 stainless will remain clean.
I sell anodised door handles, they have a pretty tough coating but not as good as stainless and are normally scratched and shabby within a year in heavy use.
Kindest regards
Alan Thomas
Alan Thomas
Sorry I thought we were having a theoretical discussion
That isn't a non destructive test.Spyder fan wrote:take a 2p coin and lightly scrape the edge against the metal, aluminium will scratch very easily, stainless will not.
That is an assumption - we can all do that!Spyder fan wrote:your sticks are almost certainly made from Grade 316 stainless steel,
Google Aluminium Chopsticks!Spyder fan wrote: aluminium is not often used for any sort of eating utensil.
Are you sure that it is the process that is vastly expensive and not the requirements of the application? You may not need to consider such close tolerances or hertzian stress in the manufacture of such mundane items!Spyder fan wrote:If the manufacturer of these rather mundane items has gone to the vast expense of applying an industrial coating normally reserved for bearing surfaces
- AHM
So, anyway I'm just wondering how many of the World's forest trees were lost in the manufacture of these metallic thingies.
And even more to the point; how many of you ask for chop sticks, which afterwards must be disposed of, when eating out at your favourite Chinese restaurant?
All of this is your fault Cleggy!
Beware of the Illuminati
Take a vote for the best answer?
Simon
Have you ever considered you may be wrong about something? How many points do you think are being awarded for your input into this topic? Perhaps like me most people are just having a good chuckle
Simon
Kindest regards
Alan Thomas
Alan Thomas
Spyder fan wrote:Simon
Oh frequently. None, hadn't realised there was a right answer or points involved. Just responding to the tone of your award winning input!
Spyder fan wrote:Perhaps like me most people are just having a good chuckle
Sorry, your humour is a little obtuse for me - I've missed it somewhere... No still can't see it.
Just having a laugh myself!
- AHM
Blimey! you must have thought about that reply! at least 5 minutes passed?!
Please excuse my banter, you obviously are mistaking me for somebody who is taking this topic seriously.... yawn! ..... thanks Pete!
Kindest regards
Alan Thomas
Alan Thomas
I would have been quicker, but I only came in to make a cup of tea and search for details on headlight mechanisms.
No, still haven't got your humour... is it this light-hearted comment?
Is there an in joke, or an anagram in there somewhere?
Spyder fan wrote: If the manufacturer of these rather mundane items has gone to the vast expense of applying an industrial coating normally reserved for bearing surfaces then the 2p alloy will act as a touchstone by depositing metal im the surface of the object, grade 316 stainless will remain clean.
- AHM
[quote="AHM"]Stainless will appear yellow next to aluminium.
quote]
Explain ?
quote]
Explain ?
Kindest regards
Alan Thomas
Alan Thomas
AHM wrote:I would have been quicker, but I only came in to make a cup of tea and search for details on headlight mechanisms.
No, still haven't got your humour... is it this light-hearted comment?Spyder fan wrote: If the manufacturer of these rather mundane items has gone to the vast expense of applying an industrial coating normally reserved for bearing surfaces then the 2p alloy will act as a touchstone by depositing metal im the surface of the object, grade 316 stainless will remain clean.
Sorry,
I'm relying on my own experience and expertise ( Architectural Ironmonger). headlight mechanisms are a total pain in the posterior, I have the dubious pleasure of exhibiting my +2 that has so called fail safe headlamps at the NEC this week. The quandary is whether to allow the headlamps to raise naturally over the 4 days or to disable the spring mechanism so that the car retains it's elegant lines rather than turning into an expensive frog eyed sprite.
Kindest regards
Alan Thomas
Alan Thomas
AHM wrote:Stainless will appear yellow next to aluminium.
To have a similar appearance the aluminium would need to be anodised. Anodise is not very electrically conductive... Stainless is.
They will have a completely different sound.lotusfan wrote:A suggestion to differentiate between the two - heat to red heat with a blow torch, the aluminium will melt, the stainless will not.
The stainless one will change colour dramalically long before the Aluminium melts.....Fool!
Your posts are not really very conducive towards peace and love are they Simon?
Kindest regards
Alan Thomas
Alan Thomas
Well, It was said in humour, as I presume was lotusfan's comment. I hope it was taken that way, I would happily apologise if not.
I reserve personal insults for humour in free parking... don't you Charlie?
- AHM
