Glove box lock removal tool
Can somebody advise of a tool to unscrew the ring that secures the glove box lock on my Elan S2?
I have tried to insert 2 x twist drills and then use pliers end on to apply a torque to them but
Being chrome, I don't want to grip the outside for fear of damaging it.
The outside diameter is 15/16"
Thanks in advance,
- a) drills are slightly too small
b) the holes are shallow,
c) holes are possibly damaged
as a result of all three the drills just rotate out when a bit of force is applied. (I also run out of hands!)
Thanks in advance,
Elan S2 DHC (26-4399),
- Barney
Just insert a small pin or allen key in the ring to fix it and start wiggeling the lock housing from the inside of the glovebox lid.
As soon it comes loose, you can easily turn the ring off
Anna
Anna
1965 S2
- Emma-Knight
Emma-Knight wrote:Just insert a small pin or allen key in the ring to fix it and start wiggeling the lock housing from the inside of the glovebox lid.
Anna
Thanks Anna, but I've been trying exactly that for at least 4 hours or so
![Sad :(](https://lotuselan.net/forums/images/smilies/icon_sad.gif)
- Barney
Sorry, I misses that.
Maybe a heated piece of tube placed on that ring to expand. (And save the wood) Then try again.
1965 S2
- Emma-Knight
I will try again, but with Allen Keys, I should be able to get a tighter fit --- perhaps!
I will stand a better chance if the pins are tight in the holes.
I am beginning to get a sense of 'deja vu' that many years ago I struggled with exactly the same problem. However, my memory doesnt tell me if, or how, I managed it before!
- Barney
elanfan1 wrote:Have you got a cheap pair of circliip pliers you could sacrifice? Heat the end up and bend the ends to face each other. That should be the tool for the job
Thanks Steve,
I'm awaiting delivery of some 3/32" dowel pins 3/8" long. These should fit the holes and allow me to use a 1" internal Ø pipe with 180° slots cut into the end face to engage the pins. Then use a Mole/Vise grips or a Stilson/Pipe wrench on the pipe.
- Barney
Barney wrote:I'm awaiting delivery of some 3/32" dowel pins 3/8" long. These should fit the holes and allow me to use a 1" internal Ø pipe with 180° slots cut into the end face to engage the pins. Then use a Mole/Vise grips or a Stilson/Pipe wrench on the pipe.
The dowel pins arrived - AND THEY DON'T FIT !!!
![Confused :?](https://lotuselan.net/forums/images/smilies/icon_confused.gif)
![Rolling Eyes :roll:](https://lotuselan.net/forums/images/smilies/icon_rolleyes.gif)
![Exclamation :!:](https://lotuselan.net/forums/images/smilies/icon_exclaim.gif)
Back to the drawing board . . .
- Barney
