Ignition timing light
Dave
No particular recommendation, but suggest you go with a named supplier rather than a Chinese copy, also one that has an inductive lead and bright xenon light, some allow you to set the timing even if the engine has no degree marks on it, as long as it has a TDC mark. A reasonably priced one will be around £50
- tonyabacus
Try and get yourself one that has a knob where you can change the timing of the flash relative to the signal from the inductive pickup. By adjusting the knob at any given set engine speed so the timing marks appear to line up at TDC you can then get a direct reading from the dial on the timing light itself of the actual ignition advance.
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
Hi Dave,
Very happy with my Innova 5568.
https://www.innova.com/products/pro-dig ... ight-5568a
This model has a “dial back” feature referred to as “advance” in the user manual. This is the feature to which 2cams70 is referring.
https://www.onallcylinders.com/2020/07/ ... g-light-2/
Colin.
quote="Donels"]I need to get a new ignition timing light. Any recommendations?
Dave[/quote]
Colin.
Dave[/quote]
'68 S4 DHC
- fatboyoz
