Is this scissor jack correct?
Having finally aquired the correct Metallifacture jack for my 68 Plus 2 I hope to try a recover some of the cost by selling the old one.
Trouble is I do not know whether it's an original late type jack?
When I got it i thought that someone had just knocked it together, so I suspect not?
Any views please?
Peter
Any views please?
Peter
1968 +2 BRM
- Peter +2
Peter +2 wrote:Thanks all for your helpful replies, especially with pictures.
As I suspected, it?s not an original one.
I will put it on eBay and see if it has any value.
Peter
Copy the original one you have, let it rust a bit then put it on fleabay as found in a Barn
- alan.barker
Are you after originality or functionality?
If the latter, I'd keep it as it is good for purpose, even if home made. There is very little difference between yours and an original 2B (late type) jack and you could easily weld a pin to it with the existing sleeve and make it look like a real one.
Edit: Oh, sorry, you have the Metallifacture jack as well. Sell away!
JonB - Coveted Fifth Gear
You could keep the 2 so you could jack up one side in the 2 positions at the same time
- alan.barker
This is the one that came with my +2 -
I made up a couple of attachments that could be used with a trolley or scissor jack -
- vincereynard
