4 speed gear selector nylon cup tool?
Hi all.
Is there a special tool to tighten the nylon cup that secures the gear selector on a 4 speed box?
I've tried a couple of different methods of tightening it but either can't get a big enough wrench in or damage the soft nylon, it's more of a pain now i have a solid gear selector but it makes me think there is a specific tool to do the job.
Grizzly - Coveted Fifth Gear
'Is there a special tool to tighten the nylon cup that secures the gear selector on a 4 speed box?'
There is Chris. It is called a strong hand. That is all I have ever used and never had one come loose, so long as you have the rough grit washer in place.
Leslie
Leslie
- 512BB
I found it helpful to put a piece of nylon hose through the opening to take off the spring pressure , and as above tighten by hand.
Then deal with my grazed nuckles
- Concrete-crusher
Getting it on the threads isn't too bad but i was struggling to get it tight, since then i've been through my tool box and found an old oil filter strap wrench, using that i have got it reasonably tight without damaging it.
https://www.ebay.co.uk/itm/Draper-13771 ... SwyKxaAuYE
I made one years ago from an exhaust pipe adaptor (2 1/2"?) hammered into a roughly hex shape. With cross drilled holes off center for a long screwdriver lever (to allow room for the shift lever). Worked well enough for one removal and reinstall.
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
- bitsobrits
