Lotus Elan
Elan lift
PostPost by: seniorchristo » Tue Nov 28, 2017 9:57 pm
Any thoughts on this type of lift? It sits on a pallet jack arrangement so can be moved around the garage. :)
https://www.ebay.com/itm/Single-Post-Mo ... SwZ4dZFa3l
67 Elan Super Safety
67 Elan +2
PostPost by: seniorchristo » Tue Nov 28, 2017 10:34 pm
67 Elan +2
PostPost by: therolfie » Tue Nov 28, 2017 11:21 pm
Friend has one and loves it!
White +2s, S4 in bits & the practical Honda!
therolfie
First Gear
First Gear
PostPost by: 1owner69Elan » Tue Nov 28, 2017 11:46 pm
Not sure I would be comfortable working under this:
single-post-lift.jpg and
I have a 2 post Max Jack which is semi portable, bolted to the floor but can be unbolted and rolled around.
Seems inherently much more stable (safe) than the 1 post design.
I also live in earthquake country. Woe is me if under this when shaking might start. Seems a bit of a delicate balance with a 1 post (unsecured to the ground) design unless I am missing something.
'69 Elan S4 SE
Street 181 BHP
Original owner
PostPost by: seniorchristo » Tue Nov 28, 2017 11:53 pm
Yeah, I'm not sure why they didn't make the base and cradle a bit larger! :(
67 Elan +2
PostPost by: el-saturn » Wed Nov 29, 2017 7:47 am
..the opponent of these could've also shown a peterbilt/mack instead of an elan (real case) which would look VERY different!! i'd love to have one those for my punk! sandy
PostPost by: alan.barker » Wed Nov 29, 2017 2:09 pm
The doughnuts or CVs won't like that dangling about :shock:
PostPost by: richardcox_lotus » Wed Nov 29, 2017 4:36 pm
And what about the exhaust.....??
'72 Sprint
PostPost by: Certified Lotus » Thu Nov 30, 2017 12:48 pm
Chris, For our light cars it looks to be a fairly good solution. The biggest issue will be doing a trans or exhaust removal as the lift arms will get in the way. You can buy a 2 Post lift for that money, the increase it cost is the installation and electric connect.
I looked hard at the max jack and decided that for the same money could get a 2 Post lift that would raise the car above my head. I wasn?t interested in the portable nature of the max jack and didn?t want the pressure hoses all over the place. (In reality the only reason I was considering the max jack was due to a 9 ft ceiling height in my garage).
You can get a four Post lift for less, but once you add in the device that lifts the car off the ramp it gets expensive.
Lots of choices, personal decision.
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
Certified Lotus
PostPost by: seniorchristo » Thu Nov 30, 2017 11:31 pm
Glen
In my case with a 1 1/2 car garage, space is limited. I would only be able to maneuver the jack in place when the garage door was down. I'll be exploring all possibilities :)
67 Elan +2
PostPost by: Certified Lotus » Fri Dec 01, 2017 12:03 am
Your right a Chris, every one of these lift purchase considerations comes with a particular need and set of space requirements. I spent 6 months researching every option before I pulled the trigger on my two post lift. Wouldn?t change a thing.
Glen
Certified Lotus
PostPost by: mbell » Fri Dec 01, 2017 2:05 am
I also spent quite a bit of time looking at lifts. For me the conclusion was a quickjack (https://www.quickjack.com) was best for my situation and requirements.
Not as good as a proper car lift but a lot better (and safer) than jacks and stands.
PostPost by: SENC » Fri Dec 01, 2017 3:06 am
I have a kwik-lift for my elan. Relatively-speaking inexpensive, and extremely easy to use. My elan stays on it whenever I'm not driving it, so it is ready for working on when I am, and just high enough to make working underneath comfortable on a creeper. I still have to jack it when on the lift to do work that requires the wheels be off the ground, but that is easily done a number of ways.
Henry
69 Elan S4
65 Seven S2
PostPost by: prezoom » Fri Dec 01, 2017 4:32 am
I bought a Max Jack because of limited ceiling height. Been using it for about 3 years with no problems. Somewhere in the past week or so, I saw an ad for this lift for $1695 with free delivery.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
prezoom
PostPost by: seniorchristo » Fri Dec 01, 2017 12:04 pm
I had never heard of the maxjax until starting this thread. It seems like a semi solution at a reasonable price. It also looks like you get to sit down while you're working :lol:
67 Elan +2
Next
