Tools tequired
I could do with obtaining the following tools:-
1) A Brass Bullet connector crimping tool, suitable for 4.7mm Bullets.
2) Gunsons ColorTune 14mm.
if anybody has either for sale, I'd appreciate a PM or telephone call on :-
Tel:07745514123
Ta,
Phil.
Tel:07745514123
Ta,
Phil.
Philip.
UK '72 Sprint DHC
UK '72 Sprint DHC
l10tus - Third Gear
Phil
Sorry to but in again but it looks like Holden do two types...
https://www.youtube.com/watch?v=68KFtQdbA_Y
john.p.clegg wrote:Phil
Do yourself a favour & buy the "Professional" tool, well worth the cost for avoiding the frustration of bad connections & wasted terminals.
Available here http://www.autosparks.co.uk/electrical-components/wiring-tools/high-quality-rachet-action-bullet-crimp-tool-giving-a-professional-hexagonal-crimp-finish.html
Took me 30 years to learn the value of good tools...
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
for bullet terminals, I use solder.........pencil torch for a couple of quids, and some cored solder makes a very positive join....
fred
fred
'Never give up!....unless it's hopeless.....'
1970 S4 dhc big valve
1973 Ginetta G15
1967 Ginetta G4 [sadly now sold]
1959 lotus elite type 14
1973 Ginetta G15
- Elanconvert
John, Fred and John,
Thanks for the replies - great info !
I've been soldering my bullets throughout the refurb process, however, I recently read an article advising that when soldering them on, the solder tends to 'wick' further up the cable, often leading to premature connection failure due to the wires' inability to flex and give.
I have had a couple of suspect connections that have failed even though they appear to have been soldered during my ownership ( although not 100% sure?).
I quite like the idea of not having to mess about with solder, flux, extension leads, heat-up / cool down periods, etc. - so I propose to give the crimping option a try.
If as successful as hoped, this will also make it a little less ' risky ' when working inside the car with the hot iron, around the dashboard plastic areas, I hope!
The write ups suggest the more expensive Hex. Crimper to be the best tool to use, so that's the way I'm tending to lean at present, should certainly be a little easier to do the final connections also, methinks?
Time will tell !
Phil.
Time will tell !
Phil.
Philip.
UK '72 Sprint DHC
UK '72 Sprint DHC
l10tus - Third Gear
phil
you are right about the heat disadvantage, and I would be very, very careful using it near a car........always remove the wire first if poss........
not sure I believe the 'wicking' story, though......... if the solder is only on the 'nose' of the bullet, and with very thin cored solder, I've never had a problem........it might happen if say you dipped the wire in flux before soldering........
fred
fred
1973 Ginetta G15
1973 Ginetta G15
- Elanconvert
Just received my latest VWP catalogue and they're here...
http://www.vehicle-wiring-products.eu/p ... ?xProd=272
A good crimp makes a "cold-weld" which has better electrical and mechanical properties than a solder joint.
From elsewhere on the web
"a good crimp takes the metal sufficiently past the yield point, but not too much, so that the "spring back" keeps the connection secure, even under thermal cycling (the coefficient of expansion of the two metals might be different) and vibration. A good crimp connection is gas tight and won't wick: it is sometimes referred to as a "cold weld".
A poor quality tool will not be able to do this, buy the best you can.
Cables do tend to fail just after the solder joint - especially if there is heat-cycling and vibration added.
Good soldering is an art - so is crimping but it is easier and quicker and you don't burn your fingers.
To my shame I cannot claim never to have used a dab of solder to rescue a dodgy crimp!
Simon
'67 S3 FHC 36/7002
'69 +2 50/1370 (stolen '00)
'67 S3 FHC 36/7002
simonknee - Fourth Gear
