TDC Tool (Prezoom)
My good buddy Rob Walker made this, So simple yet brilliant, I though I would share, If any one has done cam on a LTC timing in or out of the body you will realize how difficult it is to secure a dial indicator and measure TDC.
Thanks Rob !!!
Thanks Rob !!!
It's O.K. taking TDC from the piston movement through the plug hole ( very little movement over quite a few degrees) but much more accurate taking it from somewhere like halfway down the stroke ( equidistant BTDC,ATDC) with a timimg disc and finding the mean (TDC)...
Sorry,I thought we were talking cam timing ( 26,66,66,26 etc)...
john.p.clegg wrote:very little movement over quite a few degrees) but much more accurate taking it from somewhere like halfway down the stroke ( equidistant BTDC,ATDC) with a timimg disc and finding the mean (TDC)...
There is no reason that this dial indicator with plug hole adapter can't be used in exactly the way you describe. You just need to find something like ).060" on either side of the approximate TDC and then set up your degree wheel accordingly.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
Elan +2S (1971)
Elite S2 (1962)
If I was better at Trig. I could tell you how many degrees movement there is in 120 thou. ( 60 thou. either side of TDC ) as compared to 120 thou. ( 60 thou passing through 90 degrees BTDC and ATDC )
Maybe someone could enlighten us?
I actually made it as a quicky to find how far off the timing mark was on the crankshaft pulley. It turns out it was 11 degrees advanced. As the age goes upward, and the mind retention goes downward, I finally remembered that back in 2006 I first discovered this. But I forgot this when I went to check and set the timing. The result was a really crappy running car. It was raining pretty hard when I finished the timing routine, and I didn't road test the car. Rolling out of the driveway, early the next morning, to run up to the Queens-English car show, was a real eye opener. Performance and fuel mileage were swirling in the porcelain fixture.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
john.p.clegg wrote:If I was better at Trig. I could tell you how many degrees movement there is in 120 thou. ( 60 thou. either side of TDC ) as compared to 120 thou. ( 60 thou passing through 90 degrees BTDC and ATDC )
TDC is at the top of a sine wave with a magnitude equal to the stroke of the crankshaft.
This setup with an analogue dial gauge is accurate for locating TDC simply by measuring the needle dwell and splitting the difference.
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
billwill wrote:john.p.clegg wrote:If I was better at Trig. I could tell you how many degrees movement there is in 120 thou. ( 60 thou. either side of TDC ) as compared to 120 thou. ( 60 thou passing through 90 degrees BTDC and ATDC )
Only true for simple harmonic motion, connecting rod angle changes it.
Jon the Chief
- oldchieft
"TDC is at the top of a sine wave with a magnitude equal to the stroke of the crankshaft."-Bill Williams
Yes,and we all know how flat the top of a sine wave is...no vertical movement...
"Only true for simple harmonic motion, connecting rod angle changes it."-Jon the Chief
Yes,the crankpin/conrod just makes taking accurate readings even worse...
It's a sine wave, not a square wave.
James
James
