Best new jack to use
I'm after a new reliable jack which can be stored in the boot and used for light use such as changing wheels.
I know the original type was a scissor jack with a round jacking point attached but these don't seem to be available. The only jack with a suitable jacking point is a bottle jack. These seem OK, but I have a 2-ton which doesn't have enough height, and a 4-ton which doesn't fit until you lift the other side a bit with the 2-ton. Does that make sense? Anyway it's a complete faff and there must be a better solution.
What *new and easily available* jacks are people using?
Cheers, Ian
Cheers, Ian
Iyarno - Second Gear
I got hold of an as new jack from a scrapped Nissan Micra for ?5. To improve stability I had the base of the jack welded to a foot square metal plate (handy for soft ground too).
OK- it's heavy and I have mine securely fastened down in the boot but it sure is a lot safer than some I've seen.
- worzel
I usually use one of these double-scissor type.
They are very low when down and fit under anything; yet they lift quite high.
I don't know where you can get one though.
This one looks nice, it seems to have an electric motor to do the hard work.
But the Australian article containing that photo, does not say where you can get one. It is a warning about accidents with car-jacks.
This was on a foreign eBay, but the auction had expired, but it gives more detail of such an electric double-scissor jack.
http://www.bidorbuy.co.za/item/92705368 ... utton.html
You should be able to find a supplier of almost any kind of jack by choosing & clicking on these pictures.
https://www.google.com/search?q=car+jac ... B591%3B591
The Nissan one looks pretty much like the one illustrated. Forgot to add- I made a small wooden pad/block with a recessed part to fit the saddle of the jack. Covered the upper face with thick rubber and this is used under the corner of each sill.
- worzel
I use a Ford sill jack ( Mk5 Escort ) plus a 10mm ply pad fitted with a strip of 'T-bar' to engage in the slot in the business end of the jack. This has the advantage of all fitting in the rear wing well next to the fuel tank along with a dead blow hammer for removing / refitting the spinners.
I can take no credit for this as it was the idea of a fellow club member.
Paul
- Paul Chapman
Hi, I also use a scissor type jack that can be found at the local scrapyards for next to nothing.
I have welded a metal plate on the top to avoid the top part damaging the underside and even penetrating through the floor
Works great,
Gino
Milano
italy
Works great,
Gino
Milano
italy
1965 Elan S2 Roadster
1965 Elan S3 Coup?
1968 Elan S4 Coup?
1969 Elan +2
1968 Lotus Seven S3
1982 Lotus Esprit S3
1961 Ford Anglia
2000 Lotus Elise Motorsport-56
1965 Elan S3 Coup?
1968 Elan S4 Coup?
1969 Elan +2
1968 Lotus Seven S3
1961 Ford Anglia
gino1 - Fourth Gear
