Lotus Elan
Nice little tool (well not so little)
PostPost by: john.p.clegg » Tue Aug 14, 2012 2:51 pm
Just found this lurking in the shed during my move/clear-out,I remember going to halfords especially for the spanner and then promptly cutting it in half and roughly taping the ends over after forcing them into a handy piece of tube...overall length 24" approx....I'll give you a couple of days to guess what for before I spill the beans...
John :wink:
2012_0222lotus0001.JPG and
PostPost by: frearther » Tue Aug 14, 2012 5:32 pm
Bleeding clutch slave cylinder from the top?
Art Frederick
S2 Roadster, built in 1965, registered in 1966, No. 26/4934
Nothing else of interest at present
frearther
PostPost by: ken ob » Tue Aug 14, 2012 5:40 pm
Is it for scratching that difficult to get at itch? :lol:
Slightly confused by everything since the invention of the wheel.
ken ob
PostPost by: types26/36 » Tue Aug 14, 2012 5:41 pm
john.p.clegg wrote:.overall length 24" approx....I'll give you a couple of days to guess what for before I spill the beans...John :wink:
...Opening tins of beans that need a spanner? (never seen one myself though) :roll:
types26/36
PostPost by: ardee_selby » Tue Aug 14, 2012 8:14 pm
john.p.clegg wrote:Just found this lurking in the shed during my move/clear-out...John :wink:
Something that has had very infrequent use, eh? Is that a clue?
For opening a can of worms? Sump plug remover to drain oil at arms length? :twisted:
Cheers - Richard :wink:
ardee_selby
PostPost by: reb53 » Tue Aug 14, 2012 10:31 pm
Checking tightness of inner rotoflex bolts without having to get under car i.e. just removing wheel.
Ralph.
reb53
PostPost by: AHM » Tue Aug 14, 2012 10:35 pm
Handbrake tree
Bolt inside demister intake plenum (Is there one on the inside?)
Tightening the bolt on the front cover that you can't get at
Alternator bottom bolt.
AHM
PostPost by: twincamman » Wed Aug 15, 2012 12:13 am
Top bell housing to engine block bolts..For tightening of?...
twincamman
PostPost by: Robbie693 » Wed Aug 15, 2012 12:39 am
Looks too long to be any use for tightening anything, maybe it's for holding something on one side while tightening from the other? Bit like the coil mounting bolts where you have to grip the bolt head in the engine bay while tightening the nut in the wheel arch...
Robbie
Robbie693
PostPost by: richardcox_lotus » Wed Aug 15, 2012 7:07 am
Might be onto something there Robbie - to hold the bolts on the brake & clutch master cylinders ??
'72 Sprint
PostPost by: Tonyw » Wed Aug 15, 2012 8:27 am
Richard,
I think you are correct but the car would be in Devon and you would be in Cornwall.........
Tonyw
Second childhood? no just an extension of my first.
Tonyw
PostPost by: elanman999 » Wed Aug 15, 2012 9:00 am
For turning the engine over when checking the tappets.
elanman999
PostPost by: gjz30075 » Wed Aug 15, 2012 12:16 pm
Ok John, how about one more clue, like the size of the spanner?
Greg Z
Greg Z
45/0243K Sprint
36/5727 pre airflow coupe
PostPost by: john.p.clegg » Wed Aug 15, 2012 1:37 pm
Greg
Too late,John has it,how many times have you had to put it in gear and rock the car backwards and forwards when checking the tappets,cam and ignition timing when this little spanner enables you to rock the engine or turn it over..Drops down the front of the engine between the front cover and radiator and fits the crank pulley bolt..
John :wink:
PostPost by: elanman999 » Wed Aug 15, 2012 2:51 pm
John,
Thats a very good idea, saves you cutting the back of your hand on the radiator fins.
elanman999
Next
