Bodged vertical link
• Page 1 of 3 • 1, 2, 3
I have the front hubs stripped down at the moment for some brake work and I've discovered a small DPO problem. It appears that at some point one of the upper bolts that mount the calliper brackets to the upright has sheared off and someone has tried to drill it out. However they were unsuccessful in drilling it centrally and now there is a sliver of the original bolt sticking out around the top of the original hole and a smaller diameter hole going through. This was bolted together with a smaller that standard bolt and, because there is now no thread in the hole, a nut on the the back of the vertical link (Similar to the bolt that goes through the steering arm lower down).
I am going to try and remove this bit of excess drilled-out bolt and make the hole big enough for a standard size (5/16") bolt to go through but my question is - as the hole is going to be too big to re-thread, is it ok to have a nut on the back or do I really need a new upright?
Robbie
Robbie
Regarding having a nut on the back, I don't think that would bother me too much as long as it was seated squarely.
Before that, if my interpretation of the situation is right, I think I'd try an extractor on the remaining portion of the original bolt. Maybe with a bit of heat beforehand to try and remove it then depending on where the smaller hole is positioned, you might be able to revive the original thread with a tap.
If the smaller hole has gone off centre and destroyed part of the original thread then again I would try to remove the original bolt, probably by hitting it with a dot punch if the extractor fails. At that point I'd probably use a helicoil to recover the original bolt size/thread.
UAB807F - Fourth Gear
It's hard to comment without pictures of the situation but it's a brake component. Removing metal by drilling a bigger hole makes it weaker. If you can't remove the broken bolt without leaving the existing threads entirely intact throw it away and install a replacement. I usually find in these situations do not persist if the bolt doesn't come out easily. Take it to a professional machine shop who will remove it without damage to surrounding parts in a couple of minutes what might take you a whole day only to end up the part being reduced to something useless or damaged. Don't end up as DPO number 2.
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
- 2cams70
Thank you both. I wasn't going to attempt drilling as I have no way of keeping the drill on course and will just end up with a bigger hole in the wrong place. The original thread has been destroyed by the off-centre drilling bodge. Trying to remove the remains of the bolt was going to be the plan - thanks for the tips Brian.
I do have a photo but technology failure has prevented me from uploading it - I should be able to put one up later today. Probably with the results of my efforts too.
Robbie
Robbie
Before you go down the extractor route Robbie, if you are thinking about using the type that you have to drill a hole in the bolt first, then try and twist a reverse thread extractor into the hole, I have never had sucess with those and they usually break off, creating a worse situation. When I have posted about that before, several folk agreed.
If I did not think that I could drill sucessively larger holes in the bolt to eventually collapse it and then clean up the original hole, I would take it to some engineers who have better equipment that me, and there aren't many, to carry out the job.
Failing that, I can probably help you with a replacement part.
Good luck with it.
Leslie
Good luck with it.
Leslie
- 512BB
Robbie
I concur with others as this is a safety issue.
Is your car a baby Elan or a +2?
There appears to be two options, first a replacement part (worth an advert on here to see if someone has a spare they will part with), or to take the part to a local machine sop/engineering company that will have all the equipment necessary to do a proper repair, which may involve welding up the existing hole and redrilling and tapping the new hole. This may not cost too much.
I have assumed that the damage is to the hub and not the caliper mounting bracket
Tony
Tony
- tonyabacus
Aren't these just triumph.. only £85 new.
Current Cars: '72 Elan +2S130/5, '72 Triumph Stag 3.9L, '72 Spitifire Mk IV. Past Cars: '72 Triumph TR6 (supercharged), '70 MG Midget (K-Series + Type 9), '76 Triumph 2500TC, '72 Lotus Elan +2S130/4, '76 Triumph Spitfire 1500.
- shynsy
I did try one of those windy out stud extractors but the hole was too big for the one I have so I went ahead and did a bit of tapping with a dot punch. The shard of bolt sticking out broke off flush with the face of the upright and this enabled me to get a better view of the damage done. Turns out the DPO drilled hole is way off centre and I would never have been able to wind or drill out the remains of the bolt. How the bolt managed to go through the calliper bracket I have no idea as it is undamaged.
So I suppose I will need an new upright... Pictures are attached of before and after.
Car is a late model Plus S/130 but I think all the uprights are the same?
Robbie
Now we can see the damage and all is not lost, as I suggested you could take this to a good engineering firm and get them to weld up the hole and redrill and tap a new hole. Take along your caliper mounting plate so they can use it to mark out the exact centre needed. Lokely to be cheaper than a new upright. Have you thought about placing a wanted ad on here for a good second hand unit?
Tony
Tony
- tonyabacus
Robbie,
If you decide to go for a new link please be aware that there are instances of trunnions being either too tight or too loose on the new link. It has been reported on here, and also on various Triumph forums. I have read that some people have gone back and forth to suppliers to get trunnions and links that match.
If the link's thread, and the trunnion, are in good condition I would be inclined to go for a well engineered repair. If I had to buy a new link I would probably also ask for a correctly fitting trunnion from the same supplier at the same time.
1967 S3 FHC
1968 S4 FHC
1967 S3 FHC
1968 S4 FHC
- smo17003
I wrote a long thread about the challenges of finding good new uprights and trunnions, after reading some horror stories in a Triumph forum.
It might help you decide…
viewtopic.php?t=40847&p=285750
JonB - Coveted Fifth Gear
Thanks for the tips. I'll do some research and consider my options.
It's an offside or R/H one. The reason I was concerned about the nut on the back is that the rear face is slightly domed where the hole goes through...
Robbie
Robbie
Once you've removed the broken bit maybe you could fit a Helicoil thread Insert.
- alan.barker
