Spyder rear bearing housing
So I’ve got a failing LHS rear bearing to deal with. But the car has a replacement Spyder steel fabricated bearing housing. Are there any ‘gotchas’ with this type compared to the standard Lotus aluminium housing? In the past I’ve just heated up the original Lotus aluminium housing and knocked the axle out, after removing the retaining circlips.
Thanks for any advice.
Malcolm
Malcolm
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
Thank you, Leslie.
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
So 4 circlips in total?
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
Yes 2 inside, the inner has two grooves cut so that it will accommodates the wide or narrow bearing. Idea being, no need to machine a step in the housing. Bearings are removed as the Lotus from inside out the inside circlips remain in place.
- Craven
Thanks.
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
Hi Malcolm,
Would you mind posting the bearing manufacturer part numbers here (rather than Spyder P/N's). I've recently inherited my Fathers +2 Zetec and slowly building up a list of OE part numbers for as and when I eventually need them.
Thank you![Smile :)](https://lotuselan.net/forums/images/smilies/icon_smile.gif)
Thank you
- alex.mcguffie
Will do. Bearing housing is still on the car, waiting for a break in other life stuff so I haven’t ordered the bearings yet.
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
