+2 Rear struts - hubs
Whether the steel tubes in the ally hub bearing carrier are identical i can’t say but the ally carriers are the same if issue 18 I believe. Again don’t know if the hubs and stub axles are exactly the same but those parts are easier to find than the carriers I think
SimonH - Third Gear
A quick check of the parts manuals show that they have the same part numbers as the +2. There's a lot of overlap between the two and the parts lists in the WIKI is a good place to start.
Bud
1970 +2S Fed 0053N
1970 +2S Fed 0053N
- Bud English
I'll agree with the springs and hub part, but the Hub/Damper Assy, etc. changed to the 050 series parts commencing with chassis #7762. There are numerous 050 parts used in the later elans and 026 and 036 parts used in the +2. Remember who built these.
Bud
1970 +2S Fed 0053N
1970 +2S Fed 0053N
- Bud English
Bud English wrote:I'll agree with the springs and hub part, but the Hub/Damper Assy, etc. changed to the 050 series parts commencing with chassis #7762. There are numerous 050 parts used in the later elans and 026 and 036 parts used in the +2. Remember who built these.
Valid point.
Brian.
- ncm
