Anti-Roll Bar fitment to damper
Hello All,
I fitted the anti-roll bar to the studs on the bottom of the dampers/shocks but because of the downward angle of the bar from the chassis to the threaded stud on the bottom of each shock and and because the flat part of the bar with the hole slopes down towards the center of the chassis neither are perpendicular to the threaded stud on the bottom of the damper/shock. As a result I can't get the rubber bushes and their hats seated flush to the bar without them being squashed on one side. Am I doing something wrong here or do I just nut the bushes as tight as I can and ignore that they don't sit square on the anti-roll bar?
- mcole01
For starters, there is something very wrong with the angle of the front wishbones if the wheels are on the ground, which they appear to be. And then I notice you have adjustable shocks. You need to sort out the ride height first, and then the ARB will fit correctly, all things being equal, as they say.
Leslie
Leslie
- 512BB
Looks like you might be working with a bare chassis. If so, just wait until the car is closer to final assembly then tighten up the nuts.
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
- bitsobrits
