Lotus Elan
Best Koni setting??
PostPost by: nomad » Mon May 22, 2023 2:50 pm
What is the opinion of the group on the best setting for Koni struts for the street?? Seems rebound is all that is being adjusted. While I have you, are factory rebuild kits still available for the stock struts??
Kurt
nomad
PostPost by: elans3 » Mon May 22, 2023 7:14 pm
Both times I have had Koni's fitted, I have had them set at the softest for the road, which mimics the atandard ride , which I like.
I've tweaked them up a bit (and the GAZ fronts), when I've been on track a couple of times, then re-set them to the softest afterwards.
Obviously it's very subjective. 30 years ago, I'd probably have had them screwed stiffer, but now I like the comfort , similar to the original shocks.
Best to experiment to see what you prefer.
Previous :-
Elan S3 DHC SE SS 1968,
Elan S3 DHC S/E 1966
Elan S3 FHC Pre-Airflow 1966
elans3
PostPost by: ianthomson72 » Tue May 23, 2023 7:00 pm
When I refitted my refurbished koni inserts at the softest setting I found them to be very soft. Unfortunately TVadjusting them requires the strut to be fully compressed then the damper rod turned through “ clicks” to adjust. I’ve now set them to the middle position but have yet to get the car back on the road. I also fitted the aluminium spacers on top of the strut to bring the aeon spring into play earlier
ianthomson72
First Gear
First Gear
PostPost by: baileyman » Wed May 24, 2023 12:48 am
Are TTR 26R style adjustables Koni's? For road use, I set to softest, then periodically click firmer, then when harshness sets in, back off one or two to taste. I did find that the shocks felt hardest at new, and loosened up a bit over a thousand miles or so. John
baileyman
PostPost by: nomad » Wed May 24, 2023 4:31 pm
Thanks folks. Unfortuneatly the strut tube shocks would require a bit of work to readjust but the suggestion to go on the soft side for the street sounds like a good one.
Kurt
26/3754
nomad
