Damper Top Thread Size
Hello,
Wondering if anyone would possibly know offhand the size of the thread at the top of the damper. The part that secures onto the end of the damper shaft above the lotocone, not the thread that secures the top of the damper body in the housing.
Thx, DJS
Thx, DJS
- Gorpon73
pharriso wrote:661 wrote:I've just measured the top of my red koni's and they are 15.83mm across
=5/8”
It does, but I tried to put what I thought was a 5/8 UNF nut on it, but it didn't fit! That's why I went quiet
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
S4 SE
S2 GTS
Caterham 420R
661 - Coveted Fifth Gear
Sorry for the confusion. I was expecting them to be the same as I've had three different sets which all used the same nuts, although the nuts aren't all the same design....
I'm now working with the top adjustable Koni sports. Curious for an tool idea.
- Gorpon73
My top nuts are 11/16” UNF, which I consider a very odd size. I expect Leslie is correct, as I believe Koni are a European manufacturer. Thread systems can be treacherous as some are very similar but not quite the same. To be more certain what you have you need the diameter and the pitch. Thread pitch gauges are available and look like little saw blades with the pitch or threads per inch (TPI) written on them.
Hope this helps,
Richard Hawkins
Hope this helps,
Richard Hawkins
- RichardHawkins
