Hopping Rear
• Page 1 of 5 • 1, 2, 3, 4, 5
One the first couple of drives with the S4 I felt a pronounced bouncing in the left rear to which I chalked up to a bad strut. This caused the card bounce when driving in slow speeds. Since my local roads are fairly bumpy it fit my damper assessment. But, today I was moving the car, very slowly over a flat, smooth surface and felt the left rear lifting and falling as the car slowly rolled forward - definitely not a damper problem. I pulled the rear wheel thinking it may be out of round but rotating the hub by hand raised the lowered the body. Could this be a rotoflex problem?
Terry
Terry
- Temmck
Yes, it possible it might be a rotoflex problem, or even a tire belt/sidewall separation. Time to jack it up and have a close look at everything. If the tires are old, belt or sidewall separations are possible.
Tires are brand new. And I saw the problem without the wheel on the car. With the car on jack stands, I removed the wheel and rotated the hub by hand. The body would rise and fall with the rotation of the drive shaft, one rotation of the driveshaft, one rise and fall of the body. It's a large rise and fall - the "I can see it from across the street" kind of movement.
- Temmck
Temmck wrote:Tires are brand new. And I saw the problem without the wheel on the car. With the car on jack stands, I removed the wheel and rotated the hub by hand. The body would rise and fall with the rotation of the drive shaft, one rotation of the driveshaft, one rise and fall of the body. It's a large rise and fall - the "I can see it from across the street" kind of movement.
If the car is on jack stands how can the body rise and fall?
Are the stands supporting the body or have you somehow placed them under the struts/hub carrier, even so there must be something seriously off centres to generate enough force to move the body.
Ian
Elanman99 - Fourth Gear
As others have said there is no way that the body could be moving relative to the chassis. From what you have said it must be something driveshaft or possibly suspension top mount related.
Will be interesting finding out what is going on. Best of luck!
berni29 - Fourth Gear
Temmck wrote:It surprised me as well. The jack stand was under the suspension "A" frame not under the body. I'll try to upload a video (can you do that on this form?) tomorrow.
Assuming it is a rotoflex (and it certainly sounds like it) you ought to be able to spot the problem just by looking at them. They don't fail in graceful way.
If you support the car in a way that lets the wheels droop, that will put the rotoflex under stress and should expose any split rubber or broken bolts as you turn the wheel.
Just as a FWIW, on my Elan with ancient rotoflex it is surprising how much effort is required to turn the wheels at full droop in comparison to my Elan with UJs.
32 Standard 12
Various modern stuff
32 Standard 12
- Andy8421
This would be a good time to post some good photos.
Greg
Greg
elangtv2000 - Third Gear
So somehow you have got the car raised off the ground with the rear stands being under the A frames but still allowing the wheels to rotate. Jacking under the A frames is not recommended practice other than on the outer longitudinal tube between the outer bushes (which is quite close to the tyre so not that easy to access)
Is the rear suspension compressed such that the drive shafts are more or less straight?
Ian
I'll shoot some pictures when i get home tonight but...
When raising the corner I place 2x4 under the "A" frame as close to the brake disc as possible. I figure this has to be better than letting the suspension fully drop.
I inspected the rotoflex and they look in good condition, no cracks or other wear signs. But I do have new ones that I plan to install.
- Temmck
Seems I can't upload a video so i will attach a few picture of the situation. One show the body in the lower position and another at the upper position. It rises a little over a half an inch. it looks more pronounced in person and in the video. i also added a couple of pictures of the inboard rotoflex. i Couldn't get a good picture of the outboard but the condition is the same is the inboard.
- Temmck
Well there is certainly something amiss with the donut bolts and nuts. One nut is barely done up and has a washer underneath it. There should not be any washers in the donut setup at all and the next bolt appears to have a round head or some sort of sleeve, so that all wants looking at.
Leslie
Leslie
- 512BB
