precise size of front brake pistons
PostPost by: HardTop » Tue Jul 12, 2022 2:42 pm
Has anybody got the definitive dimensions for the front brake pistons primarily the diameter .
The tolerances on this dimension are also of interest
Thanks in advance for any info or sources
HardTop
First Gear
First Gear
PostPost by: mbell » Tue Jul 12, 2022 6:05 pm
What car/calipers? Elan v +2 had different brake setups on the front.
PostPost by: Billmack » Tue Jul 12, 2022 6:20 pm
Id say plus or minus .0005 or 7 inches from the nominal size
Billmack
PostPost by: HardTop » Wed Jul 13, 2022 11:07 am
1970 elan s4
front caliper are I believe Girling 14LF
values so far
48.1 mm
OR 1 and 7/8 inches = 47.625 mm
real values and tolerances would be appreciated
HardTop
First Gear
First Gear
PostPost by: 69S4 » Wed Jul 13, 2022 11:57 am
I have 48.05mm on two pistons - one new, one used.
Stuart Holding
Thame UK / Alpe D'Huez France
69 S4 FHC
Honda GoldWing 1800
Honda CBX1000
Kawasaki H1 500
Yamaha XS2
69S4
PostPost by: rgh0 » Wed Jul 13, 2022 12:10 pm
I measured 6 original pistons in good condition with no significant wear with a calibrated quality micrometre with zero error at 50.00 mm
Measurements were 48.10 mm +/- 0.02mm
PostPost by: 2cams70 » Wed Jul 13, 2022 12:36 pm
Any reason why this dimension is important to you?
1970 Ford Escort Twin Cam
1980 Ford Escort 2.0 Ghia
2022 Ford Fiesta ST.
PostPost by: Craven » Thu Jul 14, 2022 2:21 pm
As the originals are hard chrome plated I doubt the precise diameter is closely controlled. Surface finish more likely.
PostPost by: HardTop » Sun Oct 23, 2022 10:02 am
Thanks for all the comments
I was interested because I suspected some new pistons I had were over size
It seems from the comments I was mistaken
Thanks again
HardTop
First Gear
First Gear
