Rear Hub Fitment
Hello All,
I am in the process of fitting new rear wheel bearings (and doughnuts and diff output shaft seal/bearing) and I need to ask if what I'm seeing is normal on the rear hub. I have tightened the rear hub onto the spindle and there is a ~2mm gap between the outer bearing and the hub, is this normal? I would have expected the hub to go closer to the bearing. If the hub does not butt up against the bearing then the only thing keeping the hub/shaft/bearings from moving inboard under cornering is the circlip (and bearing fit) of the inner bearing, is this correct?
I guess the hub can't go hard up against the outer bearing as it is on a taper and small tolerance variation can alter its position?
Thanks, Jonathan
Thanks, Jonathan
- JJ66
Users browsing this forum: Billelan and 24 guests
