+2 actuating handbrake rod
Dear all
I 'm working on rear brakes on my +2 S car and i discover that actuating handbrakes rods looks not original parts and are re-welded
I'm looking for informations about correct lenth of left and right part in order to make new ones
does anyone could help me and tell me about mesurement of these parts (axis to axis)
thanks
aurelien from france
thanks
- mini90
Aurelien,
I cannot give you a direct answer as my car is a 2 seat S4. I made the rods from 4mm round bar with a long series clevis at each end. I threaded the rod to have a right hand thread on one end and a left hand thread at the other end. Clevises are available with left and right hand threads. You can get an approximate length by measuring, and then adjust for the correct length by tuning the rod between the clevises. You will need a lock nut on one end to stop the rod turning in service, but you do not need to remove anything to adjust the length.
Hope this helps
Richard Hawkins
Hope this helps
Richard Hawkins
- RichardHawkins
Clevis or fork ends or fork heads are standard components to DIN 71752. As far as I know there are standard and long series, I used long, as they allow a larger amount of angular movement.
I am not sure who I bought from but it was one of these three companies.
W D S Components.
Springfix Linkages.
Berger tools Ltd.
I don’t think any of these components or companies are UK only. I had to wait for delivery of “long left hand thread
m4” as although they are a standard catalogue item the supplier had no stock.
Hope this helps
Richard Hawkins
W D S Components.
Springfix Linkages.
Berger tools Ltd.
Hope this helps
Richard Hawkins
- RichardHawkins
