BLEEDING BRAKES
I went to bleed the brakes today on my Elan Sprint, connected Eezi bleed cracked the calliper bleed nipple on the rear left wheel and nothing, no fluid. Unhooked the Eezi bleed and tried the pumping pedal approach, got fluid at the calliper but the level in the master cylinder didn't drop and obviously all the fluid was evacuated from the system.
I am guessing that the valve head in the master cylinder is seized shut. The system has no leaks and the master cylinder 'pumps' but there is no hydraulic communication with the reservoir as far as I can see.
I am about to pull the master cylinder out for a rebuild or replacement but before I do this I just wanted to check if anyone has experienced this and had a quick fix.
Tks
Roland
Tks
Roland
- Roland
Thanks Roland
Enjoy
Enjoy
- alan.barker
Hi Roland - just before buying a new one - in general, the spring supported closing valve at the front of the masterpiston has a little black rubber seal ring. It likes to dissolve and gets sticky. It will block the passage to the reservoir. If the master body shows a clean, scratchless surface in the piston bore and the piston is not seriously pitted or scared, it’s fully rebuildable. It just takes a repair kit
(This master, crusted with grey white deposits, looks inside as fine as outside. It was put away with ol‘ Girling crimson fluid, which did no harm to the interiors, though stored in a very humid cellar garage)
Anna
Anna
1965 S2
- Emma-Knight
