Torque on caliper bolts?
PostPost by: tdskip » Fri Sep 04, 2020 5:17 pm
I may just be search challenged today, but I cannot seem to find the torque spec for the bolts that hold the calipers together (not to the car, but side to side after splitting them).
I know Porsche spec calipers use 70, but wanted to check before assuming that was close to correct.
Thanks!
SoCal
1969 Elan DHC
tdskip
PostPost by: lotusfan » Fri Sep 04, 2020 5:43 pm
tdskip
You are unlikely to find a value because splitting of calipers is not recommended, but, in the WSM I think there are generic torque values for various bolt sizes and if all else fails - 2 or 3 white knuckles should be enough!!
72 Sprint DHC
lotusfan
PostPost by: bitsobrits » Fri Sep 04, 2020 5:49 pm
The diameter and grade of the bolt needs to be considered, so comparing one make of car to another is not suitable unless they are using the same size fastener. When I rebuild calipers, if I can't find factory specs, I look up the diameter in one of the many online charts and assume a grade 8 (or 10.9 metric) to get the torque value.
You are using the factory caliper bolt or a known high tensile strength aftermarket (like ARP), yes?
And it's time for my periodic reccomendation: anyone doing their own work really should read Carrol Smith's "Nuts, Bolts, Fasterners, and Plumbing" handbook. Essential for safe, secure practice.
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
bitsobrits
PostPost by: tdskip » Sat Sep 05, 2020 12:50 am
lotusfan wrote:tdskip
My brakes sat with fluid in them since 1993 so I really didn't have a choice when it came to getting the pistons out.
I'll be using the factory bolts, will snug them up tight.
SoCal
1969 Elan DHC
tdskip
PostPost by: tdskip » Sat Sep 05, 2020 12:51 am
bitsobrits wrote:The diameter and grade of the bolt needs to be considered, so comparing one make of car to another is not suitable unless they are using the same size fastener. When I rebuild calipers, if I can't find factory specs, I look up the diameter in one of the many online charts and assume a grade 8 (or 10.9 metric) to get the torque value.
Good point, and will track that down.
SoCal
1969 Elan DHC
tdskip
PostPost by: Bombay Racing Green » Sat Sep 05, 2020 7:27 am
It’s in this video, towards the end.
https://youtu.be/UUJuW6Ho2LY
All the best.
Pete
1970 S4 DHC
1971 S2 Europa
1968 +2
Bombay Racing Green
PostPost by: englishmaninwales » Sat Sep 05, 2020 10:13 am
Apart from detail for torque setting and replacement of the cross feed seal, are there any other reasons for not splitting a caliper when refurbishing?
Malcolm
1966 Elan S3 Coupe
1994 Caterham 7
PostPost by: pharriso » Sat Sep 05, 2020 11:35 am
Bombay Racing Green wrote:It’s in this video, towards the end.
All the best.
"17 FtLbs, hopefully that will be enough"
Very confidence inspiring :roll:
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: tdskip » Sat Sep 05, 2020 2:20 pm
englishmaninwales wrote:Apart from detail for torque setting and replacement of the cross feed seal, are there any other reasons for not splitting a caliper when refurbishing?
Malcolm
Good morning Malcolm - I was taught that this was a major no-no but now having done it I honestly don't see what the big deal is. Maybe I'll have issues but this is close to stone age tech - basically two slabs of metal with a passageway in them. Unless you bugger up the faces or misplace the seal I'm not sure what can do that wrong simply by splitting them.
I could be all wrong, hopefully more experienced people will share their knowledge.
SoCal
1969 Elan DHC
tdskip
PostPost by: derek uk » Sat Sep 05, 2020 4:42 pm
Like you TD I've always been told not to do it. Reference back then was that makers bolted them together with stretch bolts selected to do the job once. Finding similar bolts impossible or difficult. Using standard bolts would be at your own risk. Calliper makers didn't quote torque for that reason. What the companies that refurb them use not known. Maybe they would be willing to fess up, but doubtful.
derek uk
PostPost by: tdskip » Sun Sep 06, 2020 12:56 am
Got this back from a VERY Lotus knowledgeable source;
“ OK to reuse bolts. TQ--5/16 bolt 15-18Ft/lbs---3/8 bolt 25-28 ft/lbs”
SoCal
1969 Elan DHC
tdskip
PostPost by: h20hamelan » Sun Sep 06, 2020 6:31 am
And like any bolts, stretch is of concern.
15 for first torque, 15.1 next...
When one re-torques, 15.2. Thus, the limit is 18(?) on said 5/16
Love your Mother
Earth
PostPost by: tdskip » Sun Sep 06, 2020 1:47 pm
Thank you for the follow up consideration.
Look at these resembled later today and pass along anything else that comes up or I find.
On a sidenote – it is encouraging to be just about out of things that I need to refresh on the car, hopefully next week will see the drivetrain fitted.
SoCal
1969 Elan DHC
tdskip
