Troubleshooting Brake Drag / Pull When Braking
Thanks Phil,
It was about 10 years ago that i bought pistons from him.
Did anyone buy his stock to carry on with supplying pistons.
- alan.barker
alan.barker wrote:Thanks Phil,
I have no idea, looks like a British Jaguar parts store bought his inventory - so I doubt it.
Phil Harrison
1972 Elan Sprint 0260K
pharriso - Coveted Fifth Gear
Show me your faulty brakes and I will take them to a clairvoyant who will read your future is the old joke.
If you suspect the pistons are sticking in the callipers then the only “sensible” thing to do is to have them refurbished or exchanged and at the same time change the discs or at least have them checked for run out, change the pads as well. This investment will last a few years and won’t be wasted.
If this doesn’t cure the problem then you should look at the track rod ends and front wishbone bushes, worn bushes and track rods will cause quite considerable pulling to one side or the other when the brakes are applied, in fact I would probably suspect this is your problem, but from this remote distance I would urge you to look at the brakes first to be safe and as already mentioned it’s a good investment.
Kindest regards
Alan Thomas
Alan Thomas
If the Tie Rod ends are shot i'm sure the Trunnions + Top Swivel will be also.
Looks like your in for a nice little project.
- alan.barker
