What are these inboard brake things - weird...
Good morning gentlemen.
Any tips or coaching on sorting out / refreshing / maintenance on the rear brakes to pass along?
I need to install new axles, do this all as one job?
Thanks!
Thanks!
SoCal
1969 Elan DHC
1969 Elan DHC
- tdskip
I got the pistons out of my rear calipers, as a reminder this car sat since the early 90s. I sent the calipers off to John Kubha for servicing, he did a great job on my engine and the axles he provided are a work of art.
I’ll spend some more time digging through prior discussions but figure that now is the time touch the rotors and be done with them.
Thanks!
Thanks!
SoCal
1969 Elan DHC
1969 Elan DHC
- tdskip
The short answer is yes - if installing new drive shafts it makes sense to sort the rear brakes at the same time.
Disc run out is critical and can be affected by the true ness of the outer drive shaft spider.
ACorrect adjustment of the hand brake pads is essential and not actually that difficult when one realises that the short little bars behind the pads are return springs.
There must be several discussions on here - try a Google search including lotuselan.net in the query and you should get plenty of useful reading.
- MarkDa
