Wheel alignment - front - loading up the car
Hi All,
I could do with some advice please on how much weight to put in the car when setting the front wheel alignment.
The +2 workshop manual seems to specify that you set the tracking with a fully loaded car, i.e, 76Kg in each front seat + 36Kg in each rear + 32Kg in boot + 23Kg petrol.= approx 280Kg / 620 lb.
This seems pretty extreme !!
Most of my driving will be with 70Kg me at the wheel + 60 Kg wife navigating. - so i think i would be better off setting the car up with just our normal in passenger weight.
Has anyone else been through the came process ?
Will be very interested to hear.
Dick
Dick
- dick+2130/5
I agree with the above.
There is such a big range of possible weights as Lotus pretended it was a real 4 seater.
Nonsense really.
Sack of sand in the boot / half a tank of fuel and normal driver + passenger weight.
Thats also how I set the corner ride heights. Unless any more learned than me tells me different!
Nonsense really.
- vincereynard
The ride height is specified rather than a load to achieve it.
Fairly detailed thread with discussion about just where to measure to and tyre sizes
viewtopic.php?t=25446&p=169671
When you know the loads required you can take them (sand bags?) to the garage to ballast car when then they do it.
- MarkDa
Users browsing this forum: No registered users and 41 guests
