Removing front springs?
I was thinking about this very job as I have springs to paint and new dampers to fit! Some years ago I made a special compressor with thin "fingers" to go in between the coils of my +2, now I come to do the little Elan and I find the spring coils are wound the other way so the angle of the fingers is wrong for them! I was considering making a new set of fingers until I saw the disc/wheel method but, I see you have bolt on wheels! I can only find one old disc as well!!
- vxah
I too didn?t have a bolt on wheel but I did have two old brake disks. It works well. I have tried the ratchet strap method and stopped fairly quickly! The threaded bar allows for a slow and controlled release.
Pete
1970 S4 DHC
1971 S2 Europa
1968 +2
1970 S4 DHC
1971 S2 Europa
1968 +2
- Bombay Racing Green
Bombay Racing Green wrote:I too didn?t have a bolt on wheel but I did have two old brake disks. It works well. I have tried the ratchet strap method and stopped fairly quickly! The threaded bar allows for a slow and controlled release.
That sounds like the winner. I do have two front brake rotors, but they?re not in bad shape and I planned on using them again. As long as I tension/release them fairly uniformly, I don?t think I?ll run into any problems down the road.
What diameter and length threaded rod did you use?
Tony
1967 Elan S3 SE
Northeast US
1967 Elan S3 SE
Northeast US
- Tmac897
Fitted using ratchets, the large ones, not flimsy ones for roof racks.
On protec damper
- grassyknoll
I use the same method as Alanr except my steel plates are circular, they had been pipe flanges that I adapted for th purpose. You need a hole in the plate that allows the spring to be collapsed/compressed whilst removing the keep. Rather like a valve spring compressor on a larger scale.
Richard Hawkins
Richard Hawkins
- RichardHawkins
I think they were either 8mm or 10mm threaded bar. I used longer nuts (about an inch long, can?t quite remember the exact term for them!). Worked well on both my front and rear Europa shocks.
Good luck.
Good luck.
Pete
1970 S4 DHC
1971 S2 Europa
1968 +2
1970 S4 DHC
1971 S2 Europa
1968 +2
