Handbrake pad helper springs
I believe it's fairly common to fit a spring on the handbrake adjuster rod to help push the pads off the disk.
Am I correct and is it worthwhile?
What spec should the spring be? Or better still where's a good source
Adrian
Adrian
1968 Elan plus 2 - project
2000 Elise S1 - Sold
- wotsisname
Arguably it's the small centralizing strips behind the pads that pull them back off the disc. But if the arms themselves don't move back contact can continue so yes a compression spring between them around the adjusting rod makes sense.
Any spring the right length would do but the usual suspects should carry them.
- MarkDa
Thanks, both. That link was a very useful read as I hadn't quite grasped the full purpose of the centralising strips.
Adrian
Adrian
- wotsisname
