Tie rod ends removal
Trying to replace the TREs on my S3. Are both sides normal thread or does one have reverse threading? So far cannot get either of them to budge. Thx
- tomjones20194
You mean track rod ends? If so they are both right hand thread as are the inner joints if you are trying to get them undone?
Have you got the jamb nuts undone? Usually they have the effect of stopping water ingress to the actual rod end and saving the threads from corrosion.. maybe yours haven?t?
- vxah
I?m trying to get the Jam nuts loose. No luck so far. I?m going to try heat next.
- tomjones20194
Don?t go mad with heat, you might have nylon thrust pads on the inner joints!
If the nuts are corroded on you could hold a big hammer head against the back of the nut and whack the front of it with a little hammer a thousand times... break the rust a bit..
- vxah
Used a little heat and got them loose. Thanks for the replies
- tomjones20194
