Spacers and bump-stops with TTR suspension in Plus 2
So these aluminium spacers were under the old bump stops and above the old Konis in my Plus 2. I've now got the TTR setup and the smaller conical stops from DBE (I asked them for something that will fit inside narrow springs). Since the new stops are shorter, am I correct to assume that the spacers should be kept? They don't fit very closely and will probably rattle around, especially as the new stops fit tightly on the damper-rod so they'll probably will stay near the top of the rod rather than resting by gravity upon the spacers. What do the experienced hands among us say?
2012 BMW R1200GS
2012 BMW R1200GS
The Veg - Coveted Fifth Gear
The aluminum spacers on my car were staked to the nut at the top of the strut tube. I had to drill those spots to release the spacer. They didn't float around.
The workshop manual hints that it is an interference fit. Simply tap it into place. Yeah, right. What they meant to say was, tap it into place then use a center punch to stake it to the nut.
Bud
1970 +2S Fed 0053N
1970 +2S Fed 0053N
- Bud English
Those new bump stops are just that - bump stops. The Aeon Rubber springs are true springs not bump stops. The spacers bring the Aeons into action sooner improving the handling of a heavily loaded Plus 2. Those bump stops will do nothing in suspension and handling terms and having the spacer will only just stop the suspension travel a bit earlier than other wise which may help from stopping the exhaust hitting the ground but not much else.
If you remove the Aeons you really need to think about either stiffer rear springs or a similar, slimmer progressive rubber spring that will fit inside your narrow springs and not a "bump stop"
rgh0 wrote:Those new bump stops are just that - bump stops. The Aeon Rubber springs are true springs not bump stops. The spacers bring the Aeons into action sooner improving the handling of a heavily loaded Plus 2. Those bump stops will do nothing in suspension and handling terms and having the spacer will only just stop the suspension travel a bit earlier than other wise which may help from stopping the exhaust hitting the ground but not much else.
Hi Rohan
Any advice on where replacement Aeons with the correct rates can be sourced? I'll be swapping mine out this Summer.
JonB - Coveted Fifth Gear
After posting it occurred to me to ask TTR what they recommend with the setup they sold me. The part number in the reply showed on their site as something that looks like what I got from DBE except in yellow instead of black. Not sure what difference that makes, although the yellow ones would have matched the car's paint better!
So for now I'm going to not worry about it, but will pay attention once the car is ready to get back on the road.
2012 BMW R1200GS
2012 BMW R1200GS
