master brake cylinder
A have the girling .7 master brake cylinder for my +2 with single servo. The screw cap looks like it is giving up and needs replacement. Anyone recommend a good alternative complete unit.
- street
Is there anything wrong with the master cylinder itself apart from a battered looking cap?
You can get replacement caps for these, they're much cheaper than replacing the entire unit.
JonB - Coveted Fifth Gear
Does anyone know where you can get just the replacement screw cap for the Sovy brake unit on the master cylinder on a +2? Mine too is in poor shape.
'71 +2 S130/4
'71 +2 S130/4
- alanr
alanr wrote:Does anyone know where you can get just the replacement screw cap for the Sovy brake unit on the master cylinder on a +2? Mine too is in poor shape.
in the US RD ent https://www.rdent.com/ offers 36J6069M for $61 (no affiliation) in white
S4SE 36/8198
nmauduit - Coveted Fifth Gear
Nicolas,
Anorak question...Do you happen to know whether the Sovy 36J6069M could be used on a large reservoir Girling 5/8" brake master cylinder ?
This looks very similar to the ones fitted to E-types (but shorter).
Andrew
Andrew
- Frogelan
Mazzini - Coveted Fifth Gear
Frogelan wrote:Do you happen to know whether the Sovy 36J6069M could be used on a large reservoir Girling 5/8" brake master cylinder ?
Hello Andrew,
I can't check much stuck as I am (no access to master cylinder or E-type parts), but as far as I know the Sovy for E-types and Lotus are of the same diameter and cap thread, only the length differs (the E-type being approx 32mm deeper inside the tank).
S4SE 36/8198
Remarkable precision!
Thanks!
Andrew
Thanks!
Andrew
- Frogelan
