Rear inner bearing play
Pardon me if this is a total nOOb question, but I've not dealt with a lot of bearings and need to learn.
Should a new rear inner bearing have this much play? It turns perfectly smoothly, no notchy spots, and there is no play perpendicular to the axis of rotation.
Have a look:
https://www.youtube.com/watch?v=BU3gRdoQDSk
So is it probably OK since it turns totally smoothly, or have I buggered it? This is the one I installed backward and have now removed.
Have a look:
2012 BMW R1200GS
2012 BMW R1200GS
The Veg - Coveted Fifth Gear
I set up a spare new inner rear bearing in a vice like you did and have around 0.020 inch / 0.5 mm of axial float in the inner versus outer race. This is typical for a single row deep groove ball bearing and different brands may have a little different end float. Visually it looked much like your video.
The spare I had was a Japanese FBJ bearing
