TTR upper front rod end interference
So I am tentatively fitting my suspension together, new 26R TTR stuff with frame. All the rod ends use a bolt as a shaft and have typical snug clearance in those situations. Except the upper fronts which use the studs on the uprights as shafts, and they are quite tight. The rod ends slide over the threaded part just fine, then bind on the unthreaded. Vernier says the ID and OD are the same within a couple thou.
Reading about rod ends, some are supposed to be pressed on in some industrial uses, and if that's the case here, I can do that. TTR says they're to be tight. But they are way tighter than any other rod end so far.
Any experience with this? John
- baileyman
They should slide on with no noticeable play, and then the inner part of the joint is clamped down solidly with a nut (or in other applications a bolt) they should not be a press fit. You should be able to hand assemble them without pressing them on or off.
1963 Unicorn
1964 S1
1965 S2
1967 S3 SE DHC
Frankentwincam 26R
Seven S2 A
Seven S2 F
1964 S1
1965 S2
1967 S3 SE DHC
Frankentwincam 26R
Seven S2 A
Seven S2 F
- knockoffnut
