Rear Hub Circlips
I'm having my rear struts rebuilt. (With pretty aluminium adjustable spring seats!)
What size are the circlips? I'm told that one is fractionally thicker than the other 3.
Is this unusual?
Best place to source bearings? I assume they are (were) of a standard size?
Vince
Is this unusual?
Vince
- vincereynard
JonB wrote:Hi Vince
Oh the fun of the rear hub experience..
Cheers JonB
That's why I gave up Jon. No manner of heat, special tools and bashing with special dead drop mallets would budge the hubs. Machine shop has a 20 Ton press. The drive shafts were, apparently, even tougher.
No chance of me shifting them.
The engineer also made up a "blind" sleeve to fit over the shaft thread and, whilst checking the shafts on a lathe, returned the thread that the removal tool has splayed.
Sometimes you just have to bite the bullet!
- vincereynard
vincereynard wrote:JonB wrote:Hi Vince
Cheers JonB
Its not clear from your description what you are actually trying to remove or dismantle.
Is it the bearings off the shaft or getting the bearings out of the ali casting that is the problem?
Ian
Elanman99 - Fourth Gear
Just watched Car SOS on tv where they smashed the casting trying to force the shaft out- they only used a 10 tonne press too! See separate thread.
free-parking-f45/friday-jan-channel-t43622.html
Pete.
http://www.petetaylor.org.uk
Pete.
Elanman99 wrote:Its not clear from your description what you are actually trying to remove or dismantle.
Ian
They are all apart now. The machine shop was asking if I knew the bearing and /or circlip sizes so he could try a bearing factor instead of the usual suspects.
MarkDa wrote:The casing fracture must have been deliberate and for show as the inboard circlip was clearly visible still in situ.
In other threads we discovered that the wheel bearings are standard industrial types.
One is used on many washing machines!
Seems a pointless bit of drama. Still the shaft should still have slid out through the bearings. Like it says in the manual! The paint prep. seemed a bit dubious as well.
I'll have to search the back thread unless a kind person can point it out.
- vincereynard
The following thread discusses the larger harder to find inner bearing. The outer bearing is 6206 - 2RS which is about the most common bearing in the world is available anywhere
lotus-gearbox-f37/outboard-drive-shaft-bearings-t32763.html
The SKF 415662C I mentioned in the post are listed as in stock by suppliers but they may be equivalents rather thna original SKF bearings so check before you buy
measuring up my spare strut and shafts and circlips i get the following
The large circlips that go in the alloy housing to locate the bearing outer races are 1.96 mm thick for fitting a nominal 2 mm wide groove. The circlip groove OD is 65 mm for a nominal 2.5 mm groove depth in a 62 mm bore for the bearing. They are both the same thickness but a metal shield goes between the inner face of the inner bearing and the circlip.
The smaller circlip that fits the shaft at the inner bearing is 1.48 mm thick for a nominal 1.5 mm groove width and the groove ID is 28.25 mm in a 30 mm shaft
You want to check your shaft and alloy housing to make sure they are the same, as items do get modified over the years and some replacement shafts or housings may be machined slightly differently.
Many thanks as always Rohan. I shall pass the info. on.
Vince
Vince
- vincereynard
My rear suspension upright/hubs were basically scrap, one had been cracked and welded, the other had chunks of alumium missing in the area of the circlip grooves. I replaced them and bought stainless circlips from my local bearing factor, in the hope that they are less likely to corrode in the grooves.
On the subject of bearings always use a good known brand such as SKF as the hassle of doing the job twice is dwarfed by the saving of a cheaper bearing.
Richard Hawkins
Richard Hawkins
- RichardHawkins
TBH Richard, SS circlips are more likely to damage the aluminium than plain steel ones. SS and aluminium are at opposite ends of the galvanic corrosion scale so if the two are in contact with any water involved the aluminium degrades to powdery dust.
Steel ones might rust but they can be painted after installing or what happens mostly is the circlip blacking or plated finish gives sufficient protection until the bearings are next replaced. Coating the SS ones in grease might delay damage but electrically the two metals will still be in contact so galvanic action is just waiting to happen.
Ian
Ian
Elanman99 wrote:TBH Richard, SS circlips are more likely to damage the aluminium than plain steel ones. SS and aluminium are at opposite ends of the galvanic corrosion scale so if the two are in contact with any water involved the aluminium degrades to powdery dust.
Ian
I see this statement all the time, and I'm sorry, but if there is enough corrosion potential to cause this, the plain steel would have disappeared long before. In a salt water boat for instance.
If it were a thin piece of aluminum in a stainless housing it might happen, but never in this case
The reason not to use stainless is that it is softer and not intended for this high load area.
galvanic corrosion in salt water boats is a real issue
not so much in cars.
- gus
gus wrote:Elanman99 wrote:TBH Richard, SS circlips are more likely to damage the aluminium than plain steel ones. SS and aluminium are at opposite ends of the galvanic corrosion scale so if the two are in contact with any water involved the aluminium degrades to powdery dust.
Ian
No need to be sorry, however 'see the statement all the time' is not the same as seeing corroded aluminium in contact with stainless fasteners. That is something I do see all the time!
Mostly the problems I see are on underwater filming equipment used in lakes and oceans. The equipment manufacturers incorporate sacrificial anodes etc but not every piece of kit is kept in good condition and on smaller items there is often not enough room. On my car which has long been non original, I replaced many fixings with stainless and it did not take long for me to see problems.
Ian
