Handbake refurb Alternate version
A slight duplication here, but this is the video that should have been published, which actually shows a before and after of the handbrake refurb.....(Senior moment)
https://youtu.be/UdVWnRLkBok
- djb222
Not critical I know but you appear to be missing the spring clip that prevents the ratchet pulling right out of the tube. Maybe you just haven't shown it ?
S4 DHC
S4 DHC
- oldelanman
I don't think the manual shows any detail of the lever assembly. The clip is about 12mm x 24mm spring steel with a raised "button" that engages with the hole near the top of the outer tube.
S4 DHC
S4 DHC
- oldelanman
The clip is not fixed to either part, just wedged between the two, which is probably why it tends to get lost. It's not critical to the function but just stops the ratchet pulling out of the tube when the cable is not connected, may also stop it rattling too.
The original mounting is a large coarse self tapper screwed down from the top into a spire nut on the bracket. Your bolt and spacer arrangement was possibly to drop the handle to make it more accessible.
S4 DHC
S4 DHC
- oldelanman
oldelanman wrote:The clip is not fixed to either part, just wedged between the two, which is probably why it tends to get lost. It's not critical to the function but just stops the ratchet pulling out of the tube when the cable is not connected, may also stop it rattling too.
My S4 had the self tapper and spire nut but it has a set of spacers to lower the hand brake.
