Strange, can'y get enough adjustment at the track rods
I've been racing an S4 this year and thought I would sort out the lack of camber on the LHF. I achieved the camber but when I went to adjust the toe I found that both track rods were at their full adjustment (fully in) i.e. I need toe in but they wont screw in any further! Does anyone have any ideas to the cause, does it mean I should remove material from the track rod ends or the track rod ? (cutting the ends is cheaper
Has anyone come across this before ? any help advice appreciated ,
- JCR1
Common problem, I?ve had the same, ended up getting a new set of track rod ends. Before you cut them down check the depth of the thread in the rod.
Thread on it here:
lotus-suspension-f42/bum-steer-t24165.html
