Knock on drive pins (pegs)
The original drive pins on my S3 with the earlier flange type pin were very corroded, and I removed them to have them zinc plated. While functional, they still looked pretty terrible, and I imagine they would capture dirt and grime in all those pits.
So I orded a set from a UK supplier who sent me pins that were useless as they were much too large in diameter to fit the hub (even when heated to 400f), and in fact were too large for the wheel centers as well (two emails from them with a promise they will "do something", then silence).
So I did some research, and drew up a replacement which I had made in 303 stainless. They are about .030 longer, as I may use Minilites, and was looking for a more positive engagement. They do still look normal with stock wheels. A very nice look once installed, and should look good for a very long time.
Made up an extra set which is going on eBay when I get a moment.
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
- bitsobrits
Should these (safety critical) items made from high tensile steel rather than stainless?
Malcolm
Malcolm
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
Stainless should be fine in this position, they are in shear only and I think even brass or copper would work.
Plain steel plated is probably the most sensible, SS does not get on with aluminium if there is any water present as Galvanic corrosion is inevitable, but unless the car is in a marine environment its probably not a worry.
Ian
Ian
Elanman99 - Fourth Gear
Thanks. Just shows I know SFA about metallurgy
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
I would use stainless steel very happily for a road car, but would lean towards something like 4340 if I was building an all out racecar.
(years ago I culdn't even spell metalergy and now I are a engineer... )
1963 Unicorn
1964 S1
1965 S2
1967 S3 SE DHC
Frankentwincam 26R
Seven S2 A
Seven S2 F
1964 S1
1965 S2
1967 S3 SE DHC
Frankentwincam 26R
Seven S2 A
Seven S2 F
- knockoffnut
englishmaninwales wrote:Should these (safety critical) items made from high tensile steel rather than stainless?
Malcolm
They only locate the wheel while it is being tightened. Drive pins/pegs is a misnomer.
BMS is fine or stainless if you wish.
Roy
'65 S2
'65 S2
elj221c - Fourth Gear
"They only locate the wheel while it is being tightened. Drive pins/pegs is a misnomer."
It's very refreshing to find someone who really understands the dynamic of this fitment.
Charlie Warner
Fatto Gatto Racing
Fatto Gatto Racing
fattogatto - Third Gear
A rose by any other name. . .
Charlie Warner
Fatto Gatto Racing
Fatto Gatto Racing
Because the center locks loosen. They must be tightened dry and checked reasonably often. If tight the wheels will not rotate on the hub at all, even without the pegs.
Charlie Warner
Fatto Gatto Racing
Fatto Gatto Racing
Call them what you will. They may serve a slight safety function in that if the wheel nut loosens some they will continue to provide drive/braking force until you can stop the car. Hopefully you will feel the wobble and pull over immediately.
However, their purpose is to locate the wheel so the wheel nut may be engaged. All drive/braking force is transmitted to the wheel through the clamping force between wheel nut and wheel.
If your wheel nuts loosen it is an indication of other issues: improper tightening, matter between wheel nut and wheel, too much anti-seize on threads, too much paint on wheels, bent wheel center from over-tightening, etc.
Charlie Warner
Fatto Gatto Racing
Fatto Gatto Racing
Craven wrote:Why do the LOCATING pin holes become elongated?
I have seen mention of enlarged holes in wheels, (which elongated holes are) but in which direction does the elongation take place?
For the holes to get enlarged, wear must have taken place probably because the nut was not tight enough
Its a long time since my S4 had steel knock on wheels but from memory I thought the central hole was oversize and the wheel diametrical location was determined solely by the close fit of the drive pegs?
Ian
