Plus 2 shock absorbers / dampers
Hi all,
Looking for some advice on shock absorbers / dampers.
I need to change front and back.
Not looking for track quality, but would like to be able to adjust return rate and ride hight.
Any direction would be greatly appreciated.
Cars:
Restoring
69 Elan +2
Running
73 Europa Special
Restoring
69 Elan +2
Running
73 Europa Special
- Cymru
I would recommend TTR adjustable spring dampers at the front and his Koni inserts at the back.
You will need to modify your Chapman struts to make the rear height adjustable by fitting threaded spring perches - however this involves chopping off the existing spring pans which you may not want to do.
- jono
didnt Kelvedon do a conversion kit?....
I didnt use their stuff but I know other have and have found it pretty easy to use, fit and set up
just a thought....
http://www.kelsport.net/parts/products. ... ctionID=26
just a thought....
What was it that Colin said ?
Oh yes....
"Make the suspension adjustable and they will adjust it wrong -- look what they can do to a Weber carburetor in just a few moments of stupidity with a screwdriver."
Oh yes....
For rear replacements I went with AVO from Dave Bean. Seem OK, but no miles on them yet as laid up for winter. I think Ray supplies AVO now as well. Interestingly, Bean?s told me they are the same rear insert callup for the Elan and the Plus 2.
Stu
Stu
Stu
1969 Plus 2 Federal LHD
i will be looking at changing my +2 shocks and springs...bushings etc. Have the Koni Square D. So I will most likely rebuild them like Dr Colonel CeeJay shows in one of his links
So it must be the coils that are different rates. and I will most likely replace with the original lotus coils for now. Recommendations as to manufacturers please.
sure I have read the rear coils compress, and strut assembly lowers out
Love your Mother
Earth
Love your Mother
Earth
I've got GAZ rears and I'm happy with them. The lack of height adjustment didn't bother me and it sits well.
On the fronts I have whatever SJ Sportscars sell. Seem pretty nice, height and dampening adjustable.
Happy with both, and compared to my shagged old suspension it handles wonderfully and very comfortable - much more comfy than my old Exige!
Elan +2 #0245
Exige S2 Supercharged
Elan +2 #0245
- Chrispy
