Front suspension Rubbers
PostPost by: Concrete-crusher » Sun Dec 17, 2017 5:05 pm
Hi , my front suspension was a few millimetres different from left to right so I have ordered new rubbers , my question is should there be washers between the rubbers and the chassis upright ?
I have seen two diagrams , one shows a large washer under the lower rubber and washers both sides of the upper rubber , whilst the other diagram shows only washers below the lower rubber and above the upper rubber.
Concrete-crusher
PostPost by: alan.barker » Mon Dec 18, 2017 6:20 am
I think for me a washer under the lower rubber and a washer above the top rubber.
I've just checked on my Sprint that had a chassis change chez Miles Wilkins so i will not question it. :roll:
PostPost by: Orsom Weels » Mon Dec 18, 2017 8:55 am
I assume we are talking about the top shock mount ? If so, no washers between rubber & chassis, just the thick dished washers above the top & below the bottom rubbers. The top rubber should have a spigot which locates in the chassis to prevent the stud from being able to contact the chassis.
Regards, Tim
Orsom Weels
PostPost by: alan.barker » Mon Dec 18, 2017 9:02 am
Yes, i was talking about the top shock mount.
PostPost by: Craven » Mon Dec 18, 2017 1:48 pm
This is an original set up with Armstrong dampers although fitted to a Spyder chassis.
damp.jpg and
PostPost by: alan.barker » Mon Dec 18, 2017 1:53 pm
Craven imho that is wrong
PostPost by: Craven » Mon Dec 18, 2017 2:33 pm
Just a quick look this is the best reference I could see! Pic I posted of shock was fitted by
? Mr Spyder ? on chassis change.
I like to see the spread of rubber bounded by a cup washer of some sort.
Ron.
PostPost by: alan.barker » Mon Dec 18, 2017 4:13 pm
The shock in your photo is not for a Lotus. Is it a coil over shock :?
PostPost by: MarkDa » Mon Dec 18, 2017 9:25 pm
I agree with Tim
MarkDa
PostPost by: Craven » Mon Dec 18, 2017 11:01 pm
Perhaps Steve would tell us the make of shock absorber he has as different manufactures have their own preferred method of mounting/isolation.
My present setup.
p1020814.jpg and
From Lotus Manual
cron
