Modification I presume?
Cleaned up my old steering coupler to use for turning the rack while checking bump steer. Was surprised to see a solid steel disk instead a flexible disk. So is this a modification or were they made this way originally? Certainly seems well done, with tight tolerances yet able to handle a fairly large angular deflection.
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
- bitsobrits
There are little tapered rubber washers on the bolts/ steel plate. Originally, the rubbers were replaceable, but finding them today would be the problem. I had a source20 years ago, but probably not today.
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
The rubber washers can just be seen in the close up. Some cracks also visible, but not looking too bad for 51 years. I am hoping not to need to dismantle, if only to for the original safety wire work.
______________________________________________________________________
just looking for clues at the scene....
- S2Jay
The rubber bushes are still available if you want to restore your coupling - Canley Classics list them ....
ITEM NO. PART NO. DESCRIPTION PRICE UNITS AVAILABILITY QTY REQ ORDER QTY
14 108977 RUBBER BUSH COLUMN JOINT ?1.99 EACH IN STOCK 8
S4 DHC
S4 DHC
- oldelanman
There should also be a wire braid going from one side to the other to earth the Horn. Because the original will not earth with the rubber bushes.
Modern replacements are all metal so no earthing problems.
- alan.barker
I took one of those off my 1973 +2 130/5 and will be replacing it with a proper universal joint, when I reassemble the front suspension. Mine does not seem to have much flexibility in it and is not able to clamp on the steering rack input shaft spline properly, despite the bolt being torqued right up.
I have to say, the bushes look cheap compared to the U/J (which was ?20). That said, I chose a U/J because I hoped it might make the column fit a bit better.
JonB - Coveted Fifth Gear
In my opinion the original joint is just a coupling which provides some insulation from vibration and shocks transmitted from the wheels through the rack, it was not designed to cater for misalignment of the column. Whilst a universal joint can be used and will accommodate some misalignment it may tend to be notchy as U/J's are designed to be used in pairs. This will probably not be noticeable if the misalignment is small and steering inputs are slow.
I think that the recent use of a single U/J in this application may have more to do with availability rather than offering an improvement over the original set-up.
Just my opinion ....
Edit:- I see the original type of joint is still available from the "usual suspects"
S4 DHC
S4 DHC
- oldelanman
Having one of each on my two elans personally i prefer the UJ, yes it feels a little harsher going over pot holes etc but the stock type rubber bush version doesn't seem to last very long before it gets a bit 'loose'.
In my opinion it's the rack mounts that make more of a difference, i fitted solid mounts and really didn't get on with them so went back to Rubber with the UJ which in my opinion is the best set up.
Grizzly - Coveted Fifth Gear
One thing you might want to look into is fitting some bracing around the Pedal box / Steering column. I found i had a lot of flex in that area on my +2 and ended up making some thing similar to Mr Murray's diagram below which really helped.
- Attachments
- bracingdrga.jpg (60.34 KiB) Viewed 1020 times
Interesting stuff. 6 Elans later I'm still learning...
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
- bitsobrits
I did think of that - there is already bracing around the edge of the pedal box (by means of aluminium angle bolted to the underside) that interferes slightly with the clutch and I know the steering wheel and handbrake are a bit wobbly.
However, I think it might be prudent to have it on the other side of the bulkhead in the engine bay (if possible - have not looked yet), because it would be easier to fit and there's something between your knees and it in the event of a frontal collision. This may or may not help.
Could you post a picture of your strengthener please, so I can see it in situ?
I found the same flexible foot box problem in my P2. Took a sheet of .060" 4130 and filled the whole underside of the box, with a cutout for the pedals and holes drilled to sandwich the fiberglass between the box and the new plate. My plate does not go back to the rear steering shaft mount, but does include the lower bracket. Problem solved.
Rob Walker
26-4889
50-0315N
1964 Sabra GT
1954 Nash Healey LeMans Coupe
26-4889
50-0315N
1964 Sabra GT
- prezoom
Users browsing this forum: Ray419G and 18 guests
