Bolt on rear hubs
Help needed
One of my bolt on rear hubs has worn "sloppy" and will not seat on the taper anymore
Does anyone have a spare for sale ?
Or even a pair?
On the plus 2 I needed a 8 mm spacer , for wheel to clear spring platform - less than ideal, somdoes anyone manufacture a hub with different offset ?
Or a drawing so I could have some made ? Either standard or modified offset
Many thanks
Or even a pair?
Many thanks
- Plus2cabby
Plus2cabby wrote:Help needed
Many thanks
Mark, Plus 2 rear hubs were made wider and were also not bolt on but knock on. You have two seater hubs fitted.
Roy
'65 S2
'65 S2
elj221c - Fourth Gear
Or even a pair?
Many thanks
Your use of the term 'worn sloppy' gives cause for caution. The fit between the hub and the shaft is a non moving joint so is not subject to wear.
If the car has been driven with the nut not correctly tightened and wear has taken place on the tapered mating surfaces then really both should be replaced. Depending on how bad the shaft damage is it might be possible to 'lap' a new hub to fit it but it needs to be done with knowledge and great care if the new hub is not to become scrap!
Ian
Elanman99 - Fourth Gear
The original cast iron bolt on rear hubs tend to bell out at the ends overtime and losing fit on the full length of the taper. Especially with heavy loads such as racing or potentially on a Plus 2 with spacers.
While it is possible with a lot lapping with valve grinding paste to get the fit back again this moves the hub inwards until it hits the bearing or the housing ( been there done that, then machined a bit of the back of the hub for clearance ).
The steel hubs now available seem to last better under high loads so far for me.
