workshop manual woes
PostPost by: Elanconvert » Mon May 29, 2017 3:13 pm
I am still finding my way around my s4, and this had me fooled for a bit...
scannedimage.jpg and
position of brake master cylinder ......the master cylinder is in the right place i.e. on the right [from the driver's seat]......bleeding the brakes but the fluid level didn't go down.....
should have taken the airbox backplate off I suppose, or looked under the dash while pressing the pedals..... :oops:
are there any [or many] other misdirections in the manual?
'Never give up!....unless it's hopeless.....'
1970 S4 dhc big valve
1973 Ginetta G15
1967 Ginetta G4 [sadly now sold]
1959 lotus elite type 14
Elanconvert
PostPost by: Lotus14S2 » Mon May 29, 2017 7:33 pm
What exactly did happen when you bled the brakes?
There is nothing to see under the dash; at least on my Elan.
You have an Elite, the process should be about the same.
If you are having a problem bleeding the brakes manually, you might consider using a pressure bleeder.
What is exactly wrong with your shop manual?
Lotus14S2
PostPost by: richardcox_lotus » Mon May 29, 2017 7:40 pm
If I read the OP correctly he was probably looking at the clutch reservoir rather than the brakes.
I too find some of the pictures in the WSM to be rather.....vague...
The earlier S2 manuals are much more precise.
'72 Sprint
PostPost by: Europatc » Tue May 30, 2017 12:03 am
I would agree with Richard, probably taken the top off the clutch reservoir
Europatc
PostPost by: Elanconvert » Tue May 30, 2017 12:24 pm
correct!
it was my elan s4, not my elite s1........
the arrow in the illustration in the manual points to the ckutch resevoir, and in my ignorance........just assumed that the brake master cylinder would be on the right behind the brake pedal......
:D fred :D
1973 Ginetta G15
Elanconvert
PostPost by: pharriso » Tue May 30, 2017 12:41 pm
You're not the first & will not be the last!
Phil Harrison
1972 Elan Sprint 0260K
PostPost by: billwill » Wed May 31, 2017 10:44 am
Didn't you get suspicious when seeing that the other reservoir was much bigger?
PostPost by: Elanconvert » Thu Jun 01, 2017 4:56 pm
alas bill....fallibility is one of my strong points.........didn't really look under the airbox backplate......
just out of interest, looked up 'clutch' in the manual and sure enough the arrow wth the legend 'clutch resevoir' is pointing to the brake master cylinder... :shock:
so even the guy who wrote the manual got it wrong........only makes me feel slghtly better...
:D fred :D
1973 Ginetta G15
Elanconvert
PostPost by: Gray » Fri Jun 02, 2017 10:06 am
I looked at a crashed Elan many years ago, the larger brake cylinder had been fitted in the wrong place! Not sure this had anything to do with the crash.
Gray
