New tyre options (UK)
• Page 1 of 3 • 1, 2, 3
Any advice on best Elan tyre options for fast road use on standard 13 inch wheels?
I had used Vredestein previously but believe these are no longer available.
David
David
David Rose
1963 S1 - Bourne bodied
1965 S2
1966 S3
1969 Europa - 210bbhp by Banks
1965 S2
1966 S3
- dunclentdr
When you decide on what tyre, you might contact these guys to obtain or to fit them. They come to you instead of you going to a tyre place.
https://www.event-tyres.co.uk/
No connection to me save as a satisfied customer for a tyre on my mundane.
I'm looking too.
It seems to come down to 3 choices so far, Rain expert or Blue earth on the cheaper side, or go all out with the Michelin XAS FF.
I have A drive's on there presently which seem to have morphed into the Blue Earth . The A drives are a bit hard. ( and old!) I have rain experts on the BMW 635CSi which I'm really pleased with.
Graeme
S4 SE
S2 GTS
Caterham 420R
Sold - Peterson JPS Exige
S4 SE
S2 GTS
Caterham 420R
661 - Coveted Fifth Gear
Cheaper than XAS and original equipment once -
http://www.vintagetyres.com/item/117/16 ... --road--tl
They certainly look the part!
EDIT -
Apparently dearer than XAS!
http://www.vintagetyres.com/search?qs=L ... +1968-1973
EDIT -
- vincereynard
I have been running Vredestein Quatrac 3 all weather tyres for 3 years now and they have been excellent.
Great grip and good wear properties. I use my S4 all year round and so went for an all seasons tyre.
They are available in the UK in both 155 and 165 x13 (I am running 165s).
They seem readily available and are under ?50 each.
1969 Elan S4 SE
1969 Elan S4 SE
- HampshireMush
Rear Tire, size problem using new modern tires. I used to use Dunlop SP10 155 13 in my sprint in original setting without any problems; now the SP10 are dicontinued and replaced by the Dunlop SP Streetresponse 2. Here the problem on the rear: they are wider than SP10 about 7 mm. The "shoulder of the tire" is more round; The SP10 was straight. The consequence is that the tire touchs the rear plate supporting the spring of the suspension.
I am looking for tires with straight shoulder. Thank you for any info from your experience.
Umberto Ferrari
Modena - Italy
Elan Sprint 7108000193K
Elite SII #1319
Modena - Italy
Elite SII #1319
- umbyfer
umbyfer wrote:Rear Tire, size problem using new modern tires. I used to use Dunlop SP10 155 13 in my sprint in original setting without any problems; now the SP10 are dicontinued and replaced by the Dunlop SP Streetresponse 2. Here the problem on the rear: they are wider than SP10 about 7 mm. The "shoulder of the tire" is more round; The SP10 was straight. The consequence is that the tire touchs the rear plate supporting the spring of the suspension.
Here some pictures showing the problem of new modern tires (too round shoulders) on S4/Sprint with original rear springs.
I used to use Dunlop SP10 without any problem; when discontinued and replaced by Street Response the problem appears, still usful at the limit by SP Streetresponse and not usful by the last actual Street Response 2.
My spare tire in the car boot is Dunlop SP strettresponse when the 4 new tires on the car are Dunlop Street Respons 2. I put the two wheels down with the external face on the floor. So I put an aluminium bar L-shape straight on the internal side of the wheels. (see picture 1)
I discovered a gap of 4 mm (see picture 2 and 3 where calibre shows 6 mm minus 2 mm of the thickens of aluminium bar)!!
The scretch circle on the new street response 2 tires caused by touching the spring plate is max 1,42 mm in deep. (see the pictures 4 and 5)
it means that a difference in tires of 2,6 mm is enough to be in trouble.
See also pictures 6 and 7 showing an evident gap face to face from the two models of dunlop tires.
- Attachments
Umberto Ferrari
Modena - Italy
Elite SII #1319
Modena - Italy
Elite SII #1319
- umbyfer
I'm in the US but we have similar problems getting proper tires.
I was running a set Sumitomo HTR200 175/70-13 that was probably 10-12 years old.
The Sumitomo fit, barely, inside the wheel arch, but required some "adjustment" of the rear spring perch to keep the tire from rubbing on it.
I am using Panasport wheels, and replaced the Sumitomo with Michelin XAS FF 155HR13.
The Michelin ride well, handle very well, restore the look of the car to original make the speedometer accurate.
The Sumitomo were old and worn and the new tires feel much better. I have no way to measure the difference between the XAS and current 155x13 tires that we have available here. I had experience with some Kumho tires on a small truck - they were awful, no traction, poor braking, poor handling. I imagine these other brands of inexpensive tires (Cooper, Kumho, UnirRoyal, etc.) are better than what was available in the 70s, but I just couldn't put them on the car.
I remember running Semperit M401 back then, in fact still have one on my spare, flat, of course. The Michelin seemed closest to that tire.
I am very happy with them. Expensive, yes, for a small tire. If you can afford it, my advice is the Michelin.
- m750rider
I was a little shocked how much the Michelin XAS FF were..... I would try them if they weren't four times the price of a good equivalent.
http://www.longstonetyres.co.uk/page/15 ... as-ff.html
Grizzly - Coveted Fifth Gear
Grizzly wrote:I was a little shocked how much the Michelin XAS FF were..... I would try them if they weren't four times the price of a good equivalent.
SP Sports the same, I loved them in 1969 but not at today's price.
I'm currently running bog standard Michelin 145/80s and they are secure and progressive in wet and dry.
Meg
Quart Meg Miles wrote:Grizzly wrote:I was a little shocked how much the Michelin XAS FF were..... I would try them if they weren't four times the price of a good equivalent.
Interesting... I didn't know they still made Aquajets (only in 165's though)
http://www.longstonetyres.co.uk/page/16 ... uajet.html
I just bought these from the U.K.
Glen
65 Elan S2 - 26/4055
72 Europa - 74/2358R
69 Elan S4 - 45/7941
64 Elan S1 - 26/0379
06 Elise - Track pack
I went to a show at weekend and bumped into an old Customer who owns a Triumph Vitesse, he showed me an article in their club magazine that was all about tyres..... Seems the tyre that came out on top was the Michelin Energy E3B...... the two things that stood out was the wet performance and it had the squarest side wall.
Another one to look at if your in the market.
Grizzly wrote:..... Seems the tyre that came out on top was the Michelin Energy E3B...... the two things that stood out was the wet performance and it had the squarest side wall.
That's the very tyre I'm running and I guess the square side wall helps keep it inside the wheel arch!
Meg
