Wheel nut dimensions?
Could some kind person give me the dimensions of the 8 sides wheel nut, across the flats and across the points please.
- vincereynard
Davidb wrote:Mine have six sides. 0.675 across flats (a bit more actually). 0.775 point to point.
Thanks David.
I don't understand 0.675. I meant side to side. Diameter flat to flat and point to point.
Vince
- vincereynard
Sorry, my mistake. I meant the single central nut.
Like these -
I'm designing a simple tool for use on the winged nut and I'm pondering on the possibility of making it so it fits both winged and "safety". What I don't know is the dimensions of the single nut. Hence the post.
Vince
Like these -
Vince
- vincereynard
Chancer wrote:Octagonal wheel nuts?
Or are you talking about one of the Knock on spinners for the US market?
You win the coconut!
- vincereynard
Thanks anyway David.
My fault I should have written "spinner".
- vincereynard
A socket for the octagonal nuts is available from RD Enterprises in the US: http://www.rdent.com.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
Elan +2S (1971)
Elite S2 (1962)
lotusfan wrote:Vince
The hexagonal nut is 63.5 mm A/F and 69.5 mm across points. I have a scrap one which you could borrow if you wish?
If I decide it is viable I'll be in touch. Many thanks.
CBUEB1771 wrote:A socket for the octagonal nuts is available from RD Enterprises in the US: <a class="vglnk" href="http://www.rdent.com" rel="nofollow"><span>http</span><span>://</span><span>www</span><span>.</span><span>rdent</span><span>.</span><span>com</span></a>.
Doesn't a socket risk damaging the chrome finish?
- vincereynard
vincereynard wrote:lotusfan wrote:Doesn't a socket risk damaging the chrome finish?
A steel socket is likely to marr the chrome finish over time although less so than the tools cut from relatively thin steel plate that Lotus supplied originally. Are you thinking of a heavy wall socket machined from brass or another relatively soft material?
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
Elan +2S (1971)
Elite S2 (1962)
Measuring my original k/o wrench shown below:
2.56 to 2.61 inches across flats
2.76-2.77 across points.
Jibes with the measurements of the spinner given in the earlier post (2.5 (63.5 mm) and 2.73(69.5mm) inches with some clearance.
As far as damage, I notice some light chrome damage in some areas on the 48 year old "Nader Nuts". But generally the wrench really didn't cause much damage. I was always careful to take any "slack" out of the wrench/spinner fit before hitting the wrench with the hammer. A socket would be much nicer as you have a real measure of the torque applied. But, I never had any problems with loose wheels.
'69 Elan S4 SE
Street 181 BHP
Original owner
Street 181 BHP
Original owner
- 1owner69Elan
CBUEB1771 wrote:vincereynard wrote:lotusfan wrote:Doesn't a socket risk damaging the chrome finish?
See the prototype of what I might make below.
10 mm steel plate. with 3 off 13mm pins welded at 75mm centres.
2mm neoprene "cover" stretched over the pins to protect the "hub".
Held in place with 1/2 inch plastic tube to protect the spinners.
Gurt big hub nut welded on the other side.
- vincereynard
Users browsing this forum: Harvey and 29 guests
