Swaybar broken - can it be welded?
Out for a drive today, everything fine. Suddenly (after normal driving) noticed some klunking in front end. Up on car ramps to investigate. Found the bolt end of the front swaybar broken. See pictures.
I just sold one a couple months ago to one of the forum members (never fails)!
Question is can it be safely welded and reused or must it be totally replaced with another one? I don't track or race it, but do "spirited" drives on the country roads.
TED
- tedtaylor
I'd add a 16GA piece the same size and shape as the top surface to bridge the break and braze it all around the join and across the break.
....and look for another.
Bud
1970 +2S Fed 0053N
1970 +2S Fed 0053N
- Bud English
Bud, if i bolster the one end to back and strengthen the broken end, the thickness would end up different from the other side. Will that make any noticeable difference?
in other words, should both ends be done the same?
Also, is the Europa front sway bar the same bar (with exception of the drop links, they're obviously longer on the Europa)?
TED
- tedtaylor
The front track width of the Europa is about 5 inches greater than the Elan.
Having one end thicker than the other wouldn't be much of an issue, but it might be worth reinforcing the other end. After all, if one end broke, the other may well do the same soon!
RogerFrench - Fourth Gear
I'd just add a bit to each side and arc weld. If the whole end is heated to red and allowed to cool slowly there should n't be a problem. My repair may make it harder to fit new bushings at the chassis attaching point though. Agree that the bushings need to be slacked a bit.
Kurt
Kurt
- nomad
SUCCESS! repair made, thick washer used to buttress each end, painted and re-installed, test driven, everything A-OK and back to normal. I did not over tighten the bushes, thanks for that tip.
TED
- tedtaylor
The rear sway bar on Lotus 22-23 etc and original 26R have bolts welded or brazed to the ends of the bars to attach the down links, so I think your braze repair will do nicely.
'67 Elan S3 SS DHC
'67 Elan FHC pre-airflow
'58 Eleven S2 (ex-works)
'62 20/22 FJ (ex-Yamura)
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
'70 Elan +2S RHD
'61 20 FJ project
'76 Modus M1 F3
- Elan45
Users browsing this forum: Robbie693 and 33 guests
