Reduced stroke rear dampers for CV driveshafts.
Anyone know the correct open length for the rear dampers, required to limit droop, to suit MM type CV driveshafts, please?
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
Not sure but I bought some AVO dampers from Kelvedon which are 172mm to the start of the D section from the screw in cap on the tube. I understand these are the 'modern' limited stroke for CV shafts.
By contrast, my Konis, which I understand to be std stroke, are 202mm on the same basis.
Plus 2 by the way but I think they're the same?
- jono
lotus-suspension-f42/rear-shock-length-for-joint-driveshafts-t30787.html
TBH i'm a little surprised the common stuff like this isn't made a Stick.
Grizzly - Coveted Fifth Gear
Thank you for the information and link.
Malcolm
Malcolm
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
Grizzly wrote:http://www.lotuselan.net/forums/lotus-suspension-f42/rear-shock-length-for-joint-driveshafts-t30787.html
Ah well it was all supposed to go into a WIKI to make a cohesive look-up system, but the word from Jeff was that using the wiki as it is at present made the site unstable.
For future reference on this issue:
Reduced length dampers supplied by Matty (Koni), TTR (Koni and also their own make), Kelvedon (currently Spax, - they previous supplied AVO) are all approximately 50mm (2 inches) shorter than the originals. Additionally Sue and Mick Miller used to suggest 50mm.
Note the early AVOs supplied by Kelvedon were 3.75 inches shorter. I've had these and are problematic, especially with fitting.
1966 Elan S3 Coupe
1994 Caterham 7
1994 Caterham 7
- englishmaninwales
