Front shocker bottom crush tube length
Re: above.
Be aware that some of these may not be quite as long as they should be. I just shimmed the bottom shocker with a washer (of the correct thickness) to equalise with the trunnion crush tube and its little end caps. You were looking at 45 thou difference which would (and did) load the trunnion as the larger bottom shocker bolt was tightened. I spent some time with the vernier getting this right as I had just poly bushed the front bones with nice correct thickness washers (as Col says). Everything is now bob on.
Elan S4 Zetec
Suzuki Hustler T250
Suzuki TC120R trailcat
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
Elan S4 Zetec
Suzuki Hustler T250
Yamaha YR5
Suzuki Vstrom 650XT
Suzuki TS185K
miked - Coveted Fifth Gear
