Camber plates?
Is anyone aware of a source for adjustable camber plates for the rear strut on an Elan?
Elan S1 1963-Bourne bodied
Elan S3 1967 FHC pre airflow
Formerly:
Elan S1 1964
Elan S3 1966 FHC pre airflow
Elan S3 1967 FHC airflow
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
- bitsobrits
I don't think that any of the usual parts suppliers have upper strut mounts which are adjustable for camber, There is not a lot of room up there for adjustment. The common approach is to use control arms which are adjustable such as this item from Kelvedon:
http://www.kelsport.net/parts/product_d ... ctionID=26
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
Elan +2S (1971)
Elite S2 (1962)
Am aware of the adjustable lower arms, and have a pair installed. The reason for seeking some upper adjustment is to move the top of the wheel in a bit to gain fender clearance (on an S3) then dial in the final camber with the lower arms.
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
Formerly:
Elan S1 1964
Elan S4 1969 FHC
Europa S2 1970
Esprit S2 1979
- bitsobrits
There is not enough room to move the Lotocone mount inwards any significant amount and it would require significant chassis mods to make it possible
I have seen a ball joint upper mount that replaces the standard rubber Lotocone. It may be possible to modify this to move it inwards to help the wheel clear the body
Does this mod cause wear on the inside edge of the tyres.
- alan.barker
I made these years ago for my 26R
Dave
Dave
Dave Hughes
S2 26R
Elan DHC Sprint
S2 26R
Elan DHC Sprint
bigvalvehead - Third Gear
bigvalvehead wrote:I made these years ago for my 26R
Dave
nice and slick... did you make some sort of custom locotone (bonded) that would fit underneath the plate or did you just use a large rubber washer (what thickness) sandwiched between two plates ?
S4SE 36/8198
nmauduit - Coveted Fifth Gear
I used a spherical bearing in the top mount.
Similar things are available for other cars these days see link below
http://www.ebay.co.uk/itm/Adjustable-Ca ... SwUKxYYiBl
Dave
Dave
Dave Hughes
S2 26R
Elan DHC Sprint
S2 26R
Elan DHC Sprint
bigvalvehead wrote:I used a spherical bearing in the top mount.
Dave
Now I understand, a real improvement over the rubber - plus should be reasonably easy to adjust on early convertible with top access. If FIA compatible/tolerated I'll sure look into it...
S4SE 36/8198
Hi, below should be some photos of mine - lucky I have the diff out at the moment.
Mine are not adjustable I just made it to be right which means light weight - saved 500g compared to alloy racing ones which were previously fitted.
Dave's do look a better than mine but I can take mine apart and put back together without the hassle of having to remeasure.
Before making I measured the standard set up checked that both sides were equal and then worked from that.
Looking at the photos my painting is shocking!
- patrics
Hi Steve
How thick is the plate you have used?
Dave
Dave
Dave Hughes
S2 26R
Elan DHC Sprint
S2 26R
Elan DHC Sprint
Below is a photo of the individual parts - not fully machined
Dave, the plate is 3mm thick - laser cut so cost is almost nothing
They obviously look simple / cheap to construct but I would recommend finish machining the spherical joint diameter and circlip groove after welding
One point is that to get to inner mounting bolt I have to pull the strut outwards to get on to the caphead
With a bit more effort they could also be made a lot lighter.
- patrics
