Blocked vertical link?
PostPost by: arthur67 » Tue Feb 14, 2017 7:57 pm
Hi just greased the trunnions offside perfect dirty looking grease coming out.But the nearside was coming out as clean as it went in does this mean it's not getting to the bottom of the trunnion?
Any ideas regards Artie
arthur67
First Gear
First Gear
PostPost by: CBUEB1771 » Tue Feb 14, 2017 8:18 pm
The path from the grease nipple through the upright goes straight to the bottom of the upright. If grease is going in it must be reaching the bottom of the trunnion. It is possible that the grease it working its way back up to the seal in a channel and so not fully flushing the trunnion. It is also just possible that the grease in your NS trunnion has stayed clean.
Russ Newton
Elan +2S (1971)
Elite S2 (1962)
CBUEB1771
PostPost by: alan.barker » Sun Feb 26, 2017 6:28 pm
"Hi just greased the trunnions"
I thought it should be EP Oil for trunnions :mrgreen:
PostPost by: Quart Meg Miles » Sun Feb 26, 2017 9:13 pm
alan.barker wrote:"Hi just greased the trunnions"
This can, and has, run and run!
Miles Wilkins supports grease on the basis that any water ingress will float on it and leave the lubricant intact, whereas water would sink through oil and start rusting the pin.
I use oil on the basis that it always fills the space whereas grease might form shapes and squeeze out leaving space for air and water. My present uprights have survived 27 years and 90,000 miles so far and were only fitted due to a little wear after 110,000 previous miles.
Meg
Quart Meg Miles
PostPost by: alan.barker » Mon Feb 27, 2017 6:09 am
I imagine you jack the car up before greasing so the lubricant can flow everywhere inside the trunnion
PostPost by: rgh0 » Mon Feb 27, 2017 9:06 am
no comment - you have heard it all before --- :lol: hahahha
