Rear inserts top nut issue in lotocone
Hi all just about to fit some rear Gaz adjustable inserts. Issue I have, the adjustment is made at the top of the unit & so a split pin isn't used. A nyloc is supplied, but the issue here is that the insert piston needs to be centred in the lotocone. The only solution I can think of is to machine a new shoulder onto the nyloc to locate it in the centre of the top of the lotocone. What have others done in this situation, or am I missing a trick here? Cheers
White +2s, S4 in bits & the practical Honda!
- therolfie
I have found an old post regarding installing a top hat to locate the piston into the lotocone under the nyloc, I will have a go at turning a couple up! If anyone know where I could purchase them in the mean time please shout. Thanks
- therolfie
In the past I've just put a shoulder on the nut. If you have a lathe it's the easiest thing to do.
- elanman999
When I fitted Spax adjustable dampers the nut supplied had a shoulder
Surely Gaz should provide proper fitting kit, it does not give confidence in there product
+2s130 1971
+2s130 1971
Hawksfield - Fourth Gear
I fitted Gaz inserts and found a couple of brass fittings that fitted into the top of the lotocones. I think they were electrical exterior fittings where you would attach an armoured cable with a rubber gland, but turning something down would be best.
The nylon nuts are tight on top but the insert' s thread should just go beyond the nylon. I had to make sure the insert was pulled right up and did this by putting some rag around the insert, gripping with mole grips and levering fully up between the coil spring. Pita to get it through the d hole in the top cup though
- KevJ+2
I should have said I'm using a Demon Tweeks 2.25 Spring kit on the rear to give adjustable platforms. This means that the top cap for the springs is thicker, it is a machined aluminium set up, hence the piston shaft sitting lower in the lotocone. I have just turned down the two original nuts & will have to thread lock them, but as I have a Spyder chassis I can make up the whole unit on the bench then offer it up as one.
- therolfie
i share rohans opinion. but i'm also sure GAZ supplied th required bits as they are sold for elans. my complete koni set, especially developed WITH TTR included everything needed, even the front spanners (to adjust ride height) and the rear Koni Knob! is TTR more expensive than spax or gaz?? - the complete package is great and worth every cent - THANKS TONY!! sandy johnson
- el-saturn
The problem I had with nylocs on Spax inserts was that they needed so much torque to overcome the nylon the damper insert just turned. In the end I had to remove the nylon in order to tighten them and I have yet to implement a more secure solution (maybe threadlock as another poster suggested).
Steve.
Steve.
- steve.thomas
Users browsing this forum: Elanman68 and 18 guests
